Motec M150 to Vette with factory BCM?
#621
If you read my reply to your question about stability I told you how it helps the tall side wall not flex as much and they don't deform nearly like a wheel with out a mechanical clamping mechanism. I don't have 17000 posts because I'm usually in the shop working on a car so I don't have time for that kind of posting, but I do have some great experience and knowledge that I freely share with ppl when I have time too. You offer some good information most of the time from what I've seen, so not trying to offend you. But others do too, we are all here just to help and learn. You seem to come off like "Build it like this." at times. Its the internet so I don't think your meaning it that way. So I was just giving you an outsiders opinion on what I've read lately is all.
Not offended at all. Missed that post, got it, and understood.
#622
Are you sure he wouldn't be slipping the tire without beadlock? He's already made close to 1500whp with the last setup and plans to make more.
Even if something is currently "working", there's nothing wrong with trying to improve upon it. I seem to recall you having several threads of no issues with coils, but replaced them anyway or similar situation for intercooler and something about a modified high ram? Nothing wrong with improving on what could be seen as working, it's how learning and innovation can come about.
Tuomas, selfishly looking forward to the new turbo build and how you lay it out. Are you going to keep exhaust all the way out the back like before?
Last summer test pulls on airfield was with low boost, 1240hp at crank on 4/5/6th gears, lower hp level on 1/2/3rd gears with boost by gear. Car was very streetable and quater mile top speed was on airfield 154 mph with 19" Toyo R888's, soft launch and no glue. Can say normal street conditions.
#623
Think will go to fuell cell in trunk for safety.
Any recommends of experiences of the different manufacturers?
Other question, does any shop offers manual steering rack for C6?
Thanks in advance!
Thanks in advance!
#624
Actually, come to think of it, I'm sure that you can build a much nicer access door that seals perfectly, etc.
https://www.summitracing.com/int/par...5700/overview/
#625
ECS makes a manual rack for the C5's I'm pretty sure it fits the C6's. TRZ's is only for there front K member, but a lot more Drag race oriented. Mad Man might make one, but not sure. But I don't see how a fuel cell is any safer on a street driven car, and doing the one in the rear you have to make a barrier for keeping the fumes out of the cab of the car which could be just as much of a challenge not to mention the fill ups etc... GL!
#627
#633
#636
#637
At least in FIA safety cage regulations only 1 bend is allowed in the vertical portions of the main tube and the A-pillar tubes.
http://www.fia.com/regulation/categ
http://www.fia.com/file/54650/downlo...token=mQiBfplj
#640
