Budget Big Single turbo 6L80 C6 Build!
hello I am finally getting around to posting my set up I have very few pictures at this point but I should have a Ton to post soon!
goals are going to be at least 1000whp on boost and who knows on nitrous. Car Will be going to TX2K15 if it kills me lol.
This a Deff 1000hp budget build!!
Set up will be
Stock ls3 block
Thompson motorsports is building the motor.
stock stroke ls3 TMS forged Crank and rods, Dimond pistons.
TMS Ported ls3 heads.
ported LS3 intake and TB.
PT88 Turbo
Custom Front mount turbo kit
Passenger front fender Exit Exhaust!!
I Will be Keeping AC!!
Large Front mount intercooler
Custom Radiator
Custom Ac condenser
Tial 44mm Wastegate
Tial 50mm Bov
Deatschwerks 2200cc injectors
Magnafuel 750 inline fuel pump
-10 feed line
-8 return
Fore innavations FPR
Fore innavations Fuel filter
I also am keeping the 6l80 in the car, Going to build it with every good part I can get my hands on.
Circle D Triple disk 3400ish stall.
Rear end Will stay stock for the moment.
LG Drag Spindles
Weld RTS 15 inch rear wheels
275/60/15 MT
I am also going to do the big brake conversion in the front to try and stop all my new found power!
I will post pics very soon!!!
Set up will be
Stock ls3 block
PT88 Turbo
Custom Radiator
Custom Ac condenser
Tial 44mm Wastegate
Tial 50mm Bov
-10 feed line
-8 return
LG Drag Spindles
275/60/15 MT
I do have a bit of a question with the use of the stock block and the conversion spindles. Not so sure the stock block is the right choice, and the 15 inch conversion is DEF not money well spent if you plan on keeping the stock rear end.
We all have budgets for sure, what I'm getting at is maybe ditch the 15 conversion and put it towards an upgraded rear? The 15 conversion is done for more sidewall and a better bite....something your rear won't take for sure. Just a thought, no hating.
Def can't wait for pix and more info.
- Travis
- Travis
not really sure on the overall budget at this point. Everything adds up so quick.
Thanks, I should be there as long as nothing goes wrong lol.
I thought about ditching the spindles for the moment and doing the rear end, but I really don't want to have any traction issues on the highway. I don't expect the rear end to last long just needs to last for tx2k and I will upgrade it. Pictures will be up soon!
- Travis
- Travis
a few pictures not what everyone wants to see but some to tie you over.
Still waiting on the turbo to show up.. been waiting over a month and still nothing!!
I have most of the fuel system. motor is lined out just waiting the turbo kit to be finished to take the motor out and send it to thompson motorsports.
Transmission I have been talking to PATC on buying all the transmission parts to build it.
Has Anyone used one of their built 6l80's???
but now on to the pictures..
Little change of plans on the motor.
We decided to run a 6.0 iron block instead of the ls3. So now it will be a
Thompson Motorsports 370
Tms forged crank
Tms h beam rods
Diamond -2cc pistons
Arp 2000 rod bolts
Arp main stud kit
Cnc ported ls3 heads
Brian tooley 650 lift valve springs
Toms big boost cam
Billet timing set
Stock rockers with the trinion upgrade.
Arp head studs
Compression will be 11.3 ish. Fuel will be E85 only.
Motor should be to me on February 4th.
Turbo pics coming soon.
Tms forged crank
Tms h beam rods
Arp 2000 rod bolts
Arp main stud kit
Toms big boost cam
Billet timing set
Arp head studs
Added a few more pics to the first post. Ac condenser was cut Down a few inches,
custom radiator bracket and the crossover pipe in place. Getting close to the end. Waiting on a few clamps to build the custom 4 inch down pipe that will exit the front bumper.
Received 1,194 Likes
St. Jude Donor '15
Some of these builds on here are all out 50-60k builds. lol
I am Doing all the labor myself aside from the turbo kit fabrication.
I work at a performance shop so i know how far 20-30 grand will get you paying retail for parts and paying someone to install it all.
I hope to have nowhere near that in mine and still be able to out run them!
