Post Pictures of Gauge pods please - Page 4 - CorvetteForum - Chevrolet Corvette Forum Discussion
C6 Forced Induction/Nitrous
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Old 06-15-2017, 09:52 PM   #61
Mrbluedevil88
Junior Member
Quote:
Originally Posted by NJ_phil View Post
Who makes that pod and how do you like it?
Mrbluedevil88 is offline   Reply With Quote
Old 06-16-2017, 07:25 AM   #62
NJ_phil
CF Senior Member
Support Corvetteforum!
NJ_phil's Avatar
AutoMeter 12195:
https://www.summitracing.com/parts/a...FQhAGwodhpMKqw
http://www.westcoastcorvette.com/p-2...5-2013-c6.aspx
I have a brand new double (2 pods) if you want it. $25 + shipping but no plastic push pins to mount it to the pillar cover
https://www.summitracing.com/parts/a...FVEYGwodWD4BWQ
EDIT: It's really nice. I like the fact that it's right there in the field of view when making pulls so I don't have to look down at the dash. The AEM X-Series match the factory gauges pretty much and blend right in. Was almost ready to go with their Cobalt line but went with X-Series because of OBD connectivity
NJ_phil is offline   Reply With Quote
Old 06-16-2017, 10:14 AM   #63
schpenxel
CF Senior Member
St. Jude Donor '15
schpenxel's Avatar
I wish the SLP pod didn't fit so horribly.. I'd really like to use it for a wideband.
schpenxel is offline   Reply With Quote
Old 06-16-2017, 10:28 AM   #64
NJ_phil
CF Senior Member
NJ_phil's Avatar
Quote:
Not sure if you mean the one below, but yes it's crap. The first thing I did when getting in the car is push it back under the OEM trim because it never fit right. Gauges were a cluster **** in my car, mounted the SLP, drilled the cluster bezel, bought the 3 pillar, collided with the SLP, had to put a cluster cover in. Ugh. Rather pull the rack out that deal with that again
Old 06-16-2017, 10:42 AM   #65
schpenxel
CF Senior Member
St. Jude Donor '15
schpenxel's Avatar
Yeah that's the one I was thinking of.. man you've got more electronics in your car than me. I didn't know that was possible
Old 06-19-2017, 05:54 PM   #66
C U IN REARVEIW
CF Senior Member
C U IN REARVEIW's Avatar
Commanded Lambda, Wideband reading, knock retard degrees and boost/vacuum in psi
THIS is how I want mine to be setup.....have everything to do it.....just can't seem to get my wideband/fuel pressure formulas correct...
C U IN REARVEIW is offline   Reply With Quote
Old 06-20-2017, 11:00 AM   #67
schpenxel
CF Senior Member
St. Jude Donor '15
schpenxel's Avatar
What's it doing or not doing?
Old 06-20-2017, 02:27 PM   #68
stevenb8
Junior Member
stevenb8's Avatar
For those with Pillar install where did you run your wires etc through. Any easy routing tips - tricks for smooth install? I have two gauge pod and aem air fuel and boost gauge to mount.
stevenb8 is offline   Reply With Quote
Old 06-20-2017, 02:39 PM   #69
g23crawler
CF Senior Member
g23crawler's Avatar
Quote:
I ran mine under the weather stripping through the side of the pillar into the top of the fender. If that makes sense
g23crawler is offline   Reply With Quote
Old 06-25-2017, 12:55 PM   #70
C U IN REARVEIW
CF Senior Member
I can't get the wideband #'s correct in dashlogic (using plx formula)....but reads correct on gauge...?
Old 06-25-2017, 12:57 PM   #71
C U IN REARVEIW
CF Senior Member
Vs. Dashlogic?
Old 06-25-2017, 04:32 PM   #72
schpenxel
CF Senior Member
St. Jude Donor '15
schpenxel's Avatar
Quote:
How far off is it? And do you have a dedicated ground wire ran from the PLX box to dash logic?
Vs. Dashlogic?
I'd do both if SLP pod fit better but if I had to do one or the other it'd be DL
Old 06-25-2017, 04:48 PM   #73
C U IN REARVEIW
CF Senior Member
Off by a good bit. Will have to look at it again....been awhile since I messed with it
Old 06-26-2017, 09:17 AM   #74
ls1wolf
CF Senior Member
ls1wolf's Avatar
My dashlogic PLX wideband reading is a bit off as well. saying 13's AFR (when HPT is showing mid 11's)
ls1wolf is offline   Reply With Quote
Old 06-26-2017, 01:32 PM   #75
schpenxel
CF Senior Member
St. Jude Donor '15
schpenxel's Avatar
Weird. Same formula?
Old 06-26-2017, 04:19 PM   #76
ls1wolf
CF Senior Member
ls1wolf's Avatar
yep
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • Post Pictures of Gauge pods please
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    WTB: WTB: Triple Pillar gauge pod billetproof97' C5 Parts for Sale/Wanted 8 08-08-2017 03:10 PM
    WTB Gauge Pod Sergio7 C6 Parts for Sale/Wanted 0 03-03-2017 12:47 AM
    WTB SLP single gauge pod EVERFLY C6 Parts for Sale/Wanted 5 02-26-2017 11:51 PM
    WTB: piller pod 2000CorvetteFRC C5 Parts for Sale/Wanted 5 02-03-2017 11:12 AM
    WTB: SLP Gauge Pod KevinD92 C6 Parts for Sale/Wanted 1 06-22-2016 09:58 AM
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    Sponsored Ads
    Vendor Directory
    • Ask a Question
    Question Title:
    Description:
