ysi belt slip?
ysi belt slip?
I am currently running an A&A 2.85 blower pulley with 10% overdrive innovators west crank pulley. It is all 8 rib. I'm having quite a bit belt slip! Boost is peaking at about 16lbs at 6,000 rpm then dropping from there up to 7,000 rpm. I know 10 rib would be better, but for now I just want to get the most I can out of 8 rib. What blower pulley is everyone running to get max boost without slip? I was leaning towards 3.00 but not sure.this is on Z06. I figure my boost should be around 18 to 20 with this set up, but I understand that every car is different and that boost is not the most important factor, but I know I am having slip.
Thanks for any advice. I'm already running a direct drive.
I run the same setup as you, A&A, YSI, 2.85, 10%, Direct drive. Run up to 7100 rpm with no issues. Good luck going to a 10 rib. You cannot do it with the A&A bracket and run that size pulley. Are you running a dedicated belt for the blower? That may be you issue.
I run a a&a 10 rib setup with a modified tensioner and a 2.70 blower pulley / 8" crank pulley. DP direct drive cut for 6 rib a/c drive opposed to the original 4 rib. Logs with this setup show no slip and I get very little belt dust. I run the green Kevlar belts, properly aligned they last a long long time, going on 3 years and over 15000 miles.
St. Jude Donor '10-'11-'12
I am getting 15.5/ 16 psi also on a built motor 427, Mast 305 heads. Same pulleys as you with a Cartek direct drive. Taylor at Dallas Performance said he didn't see signs of belt slip.
Received 1,260 Likes
I spoke with Josh at A&A at length and he said I could not run the 10 rib with a smaller pulley on the newest bracket design. The older bracket tensioner would not hold up. I had already purchased the IW balancer and was really pissed to hear about this. Can you pm some details of what you did to make it work and with what A&A bracket design. I already have the DP direct drive with 6 rib C5 bracket a/c setup.
I just bought the newest design a&a procharger bracket set up for 10 rib, I would assume their vortech brackets are virtually the same as far as the way they operate... I also got the heavy duty tensioner, it looks the same as the standard tensioner but they weld a plate on the back and install a bolt through the middle
Yes, I'm running a dedicated belt for blower. What length of belt do you run?
That's what I am seeing but there is slip. Boost is peaking at 6,000 rpm and falling down to 15 at 7,000. Got plenty of belt dust, but belt is running true.
With my 3.0 I am using belt KO80537HD. It would be the same for the 2.85 on my car.
The pulley in this pic is the 2.85 with grooves, although I decided to use the 3.0 in the end.
You might try one of those A&A pulleys with the grooves cut in them, if you are not already. I am using that and get no slip as mentioned.
