Project: Doing it myself
#41
I knew u would get er done! Semper Fi! Thanks for sharing more pix.
#42
Killer build man! I can appreciate the effort you put into it. It's a slippery slope.. Enjoy the ride when it's good...
ERL short block is the way to go. Make sure to get a GOOD crank/rods. Not Compstar stuff. Spending more on the motor upfront now will save you a fortune later.
Good luck on hitting 8s!
#43
I would re think the wiseco pistons. Diamond uses a better alloy, make sure you get heavy wall tool steel wrist pins as well, not the standard ones. Dragonslayer crank, ultra I beam rods, will make for a stout bottom end. Have your main caps pinned as well.
#44
I just looked. It says erl custom pistons. I assume I have a choice between the two.
#45
Any updates on this build?
#47
Received 1,194 Likes
St. Jude Donor '15
I just installed the balancer and re-pinned the crank in a new spot, no problems.. The square key is for aftermarket cranks with crank keyways. The rounded dowel pin, I'm assuming, is from the crank having been pinned before.
#48
How can I do that without messing up the crank or the balance?
#49
St. Jude Donor '15
#51
St. Jude Donor '15
ATI has one that is different and using it you end up utilizing the slot that is in the balancer, but it costs more and doesn't really matter in the end.
The one ECS uses just drills a slot in the crank and balancer, so half of the drill bit goes into the crank and half of it goes into the pulley, then you put a steel pin in that helps stop the balancer from spinning. I've got some pictures from my install if you want them (these are just random ones I found on the internet)
Kind of like this:
#52
Yeah that's what you need. I have one if you want it but you'll need a pin still unless you have an old one or something
Kind of like this:
Kind of like this:
#53
St. Jude Donor '15
#54
#55
St. Jude Donor '15
Here's what mine ended up looking like FYI
#56
Any update bro?
#58
Damn that sucks bro use broken bolt extractor?
#60
St. Jude Donor '15
