Clutch change with Supercharger
Was wondering if anyone here has ever had to change a clutch with an Edelbrock E force..
Spoke to a shop today and they quoted me $2500 just for installation of the clutch for my vette, because they have to take the e force, because it wont allow the motor to tilt enough to drop the tranny blah blah blah
has anyone else experienced this issue? please any steer in the right direction would help cause my clutch is pretty much completely gone..
thank you.
thank you.
$2500 is crazy just for labor and you don't have to pull the supercharger to change the clutch. Normal labor is usually around $1K.
That's what I said, after looking thru the forum for a couple of days $800-$1000 is the range I was expecting, they said that with the E force it wouldn't allow them to tilt motor enough since it sits on top.
thank you.
thank you.
Received 1,194 Likes
St. Jude Donor '15
I'll cut you a deal.. $2,450
So your saying regardless of the fact that it has the E force you should be able to do the clutch swap no problem?.. Because if so, looks like I'm making a trip up to bradenton to do it with you guys..
$2500 with parts is even steep. Maybe he is sayin he has to take off blower to get at the bolts on bellhousing?? Im not sure on the clearance between the blower and firewall/base of the windshield there but I'm sure it's pretty tight. Either way $2500 even with parts seems steep. $2500 with clutch, remote bleeder, new flywheel and installation would sound a little more reasonable. But def. make sure whoever does the clutch does a remote bleeder.
What kind of clutch are you going with?
Yes it was $2500 not including the clutch ! Thats why I almost had a heart attack.. The shop said they wouldn't be able to do the install without removing it, which I'm having a hard time believing that. I'm most likely going to be doing a Mcleod RXT twin disc.
Ya +1 to RXT! An make sure its not the RST.
But on the other subject, i would look into another shop.
They may be correct in saying that you have to pull the edelbrock but I think you can still get a better price.
I was quoted $2000 forRXT install with remote bleeder. So if they do have to pull the blower it shouldn't be much more. I havent seen the e-force in person but it can't take more than an hour to remove. Once you get the belt removed it's like remiving an intake manifold.....maybe a dozen bolts?
St. Jude Donor '13
We have a deal going on right now which is the McLeod RXT Twin Disc Clutch Kit, McLeod Steel Billet Flywheel, GM Slave Cylinder, Motul Fluid, Installed for $2300. The Mantic 9000 Twin Clutch Kit which comes with the Steel Billet Flywheel, GM Slave Cylinder, Steel Billet Flywheel, Motul Fluid would be $2350 installed.
Yep not a problem.
Thanks for reaching out ! Well after reading that we will definitely be in touch Matt, sounds like a lot better of a deal then I was getting.
If you do remote, do the katech. I wouldn't touch any other. It is the only quality one I've seen.
No reason to touch the blower to do a clutch. $2500 in labor you could remove the whole drivetrain, replace the motor on a stand, and put it back in. That is crazy.
St. Jude Donor '15
Several of them try to use an off the shelf fitting to screw into where the original bleeder screw goes.. which doesn't seal very well and thus leaks. I am assuming the Katech one uses a custom cut piece so that it actually seals properly. Monster does the same, but I've never seen one in person.
ECS uses an off the shelf AN style fitting with a washer between the fitting and the slave to act as a seal. Mine has worked fine so far, but I also did a very good job smoothing out the surface that the seal actually seals against on the slave, and I use a new seal every time I touch it.
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,085 Likes
We manufacturer the lines here ourselves and to date have never had one leak that I have ever heard of. I also used to not be a fan of them which is why we started making them ourselves. However when they do work properly it makes changing out the clutch fluid so much nicer.
St. Jude Donor '15
The hose itself does look nice and has crimped fittings. I like that the hose is covered in a clear cover so you don't have to worry about a braided stainless line rubbing up against/through stuff.
I have not had any hints of a leak with the ECS remote bleeder, and we all know I have mine apart monthly, so I'd know
I just would try to do a good job cleaning up the area where it seals on the slave side. Bottom of first page of the instructions. I took a random orbital sander with some really fine paper on it (like 1500 fine) and damn near polished the thing to a shine. Overkill? Probably.. but it worked fine for me.
http://www.eastcoastsupercharging.co...014_102714.pdf
