How much hp is too much for a stock bottom end LS7?
Hello all. I thought it would be good to have a consensus on what it the power/torque limit on a stock bottom end LS7.
I have a stock bottom end LS7 C6 ZO6 and I'm putting out 690 hp and 736 tq to the wheels on a Dyno Jet. With the new blower-friendly cam, I should be somewhere around 710 hp.
Is this too much? Where is the horsepower/torque cut-off for a stock internals LS7 before it's in the danger zone and becomes a ticking time bomb waiting to blow up?
i got a built forged engine and sold the stock short block. i didnt trust the ls7 to handle too much abuse at mid 700s so i got a forged engine built while the stock bottom end was worth selling
Received 1,194 Likes
St. Jude Donor '15
-Curtis
You're fine no one here has pushed it too far yet. They've been in the 800's just fine. The LS7 is forged from the factory besides the Pistons the rods and crank are forged. It can take alot. I'm getting dyno tuned this weekend. I'm going for 850-900 with a single turbo setup on E85.
-Curtis
-Curtis
-Curtis
-Curtis
Big thing to remember here is most guys making big numbers on stock short blocks only make the engine see that power for short spurts down the highway or some roll event. The question isn't how much power the short block can take, but how long the short block has to endure that power. This is where stronger internals and sleeves come into play.
So you mean even after having a fully forged motor made and running mid 700 hp, it STILL blew after 2 years?
No he said he was running mid 700hp for two years on stock ls7 block with no problems. (Pump gas only). But he built a forged block and swap out the stock ls7. Before it blow up.
as above. you can sleeve and piston your stock block as they are the 2 weak points but i spent a few more bucks and started with a fresh block and sold my short block. not much more to do it that way then you can throw mad boost at it too. i went rhs but erl or lsx is a cheaper option.
I ran mine hard for 2 years at 700whp, H/C/N2o and performed great. Even did a couple 1000 mile road trips still getting 30mpg. Anything beyond 750wheel seems to be sketchy territory. Might as well sell the longblock (if it's low miles) for a decent price and build an ERL or RHS if you want to make more power than that. I've heard of a couple LS7's doing mid 800's but I can't imaging those cylinder walls lasting long.
I feel like I will only get about $7,000 for my long block with 20,000 miles on it, and I'm being quoting by LME (Late Model Engines) about $27,000 for a fully forged Dart all aluminum motor with heads flowing 400 and the billet intake manifold. -That's a crap load of money that I'd rather hold onto.
I'm really hoping not to spend all that money on a completely new motor. I'm only planning on keeping it at 7.4 max PSI and about 710 or so hp at the wheels.
St. Jude Donor '15
Sounds like overkill to me.
-Curtis
-Curtis
I can't believe you have a stock LS7 and you're making well past that. Only a matter of time. Even an amateur like me knows that.
Good luck and God bless with that set up bud!
St. Jude Donor '15
Why billet intake?
