Tail Q bov
Tail Q bov
Does anybody have any idle issues after installing the Tail Q on there supercharger set up? I have the bov mounted on the intercooler and it surges at idle and while cruising. My engine vacuum reads 7 and I have the 8psi spring in it. Don't know if I need a smaller spring.
Received 1,194 Likes
St. Jude Donor '15
Yes... agree with everyone else
The valve should be OPEN when under vacuum. i.e. idle and cruise. It will CLOSE when you get up to about -2 psi in the "boost" scale.
Kind of backwards from the way a blow off valve works for a turbo setup. I usually call a supercharger one a bypass valve instead of a blow off valve.
I mount all of my BOVs PRE intercooler. It helps dampen the erratic flow that will cause driveability issues when its open. There is a lot of turbulence in that area, and the further from the MAF the better.
