ECS restrictor plate
Im patiently waiting for my ECS S/C kit to come in
Now i will have a BAP, 60LBS injectors and alky control meth.
The big question is whether or not im using the restrictor plate? I know ill see more boost without it, but i question is if im taking away some torque as well? Anyone could shime in to help me figure out what is the pros and cons! I dot wanna give up torque/response for more HP, or it doesnt really change anything? Thanks in advance!
Received 1,193 Likes
St. Jude Donor '15
It limits boost on the top end. It's affect is less apparent on low end/midrange.
I personally have left it in but opened it up to about 2.9" or so. Stock LS2 here
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,084 Likes
I would pull it if it was my car, but that's just me.
__________________
C5/C6 and C7 Supercharging Specialist
ECS Supercharger Kits / Mantic Clutches
www.EastCoastSupercharging.com
Facebook Page
ECS YouTube Channel
Facebook Page
ECS YouTube Channel
St. Jude Donor '15
Yep... exactly, on the conservative part. I'm sure I'll pull it at some point, but not yet
1.) The amount of stress being put on a stock block
2.) The lack of traction on a street car
3.) Causing other potential weak links exposed and develop a failure elsewhere
At 640 RWHP on a Mustang dyno, opening up the restrictor to push 700 RWHP + is just going to cause tire shredding up to triple digits. I can't exactly go around on a daily driver with MTs out back.
Doug would know better than I, but I wouldn't pull the restrictor on the 60# injectors personally. I assume the only reason he would suggest it is because you will have the Meth for extra fueling which works fine I guess, I just prefer to have the required fuel without the Meth and then add it for safety. Both ways will work though. Just have to decide which way you want to go.
I can give you three from my personal stand point...
I don't run the restrictor on mine on RE11s 1st and 2nd would spin no issues but 3rd was fine(base gearing) and now with MT drag radials it hooks 2nd fairly often.
So honestly I doubt the restrictor is really going to change much since you're limiting peak boost the smaller pulley is still making all that mid range torque which is killing the tires.
Either way, I'm going to have to up my tire even though it's a daily.
St. Jude Donor '15
Yeah, mine breaks loose at higher RPM's in third too. Restrictor plate still in.. so I can only imagine it'd get worse without it. Maybe I'll try it for kicks
Received 1,261 Likes
at 450whp I'd get >11k miles out of my nt555r with a pretty good amount of hooning on a daily basis and they hooked that power level up great even in 1st gear on the street without burnout, of course 650-700whp is a different ball game but i'd think 10k miles is not unreasonable and they worked great as a dd tire imo.
600 rwhp and 553 rwtq on my LS2 A4, stock block & trans, ECS kit and Alky Meth kit @ 11# of boost. All is well here!
I dont get why everyone is afraid of meth?! With the proper failsafe, you could tune to make more power on meth. Then with multiple failsafe you could trigger timing cut back to get limp mode if whatever happens with the meth spraying.
