Let's see some aftermarket valve covers
Doesn't matter if they're yours or not as long as they'll fit on a LS head. What's everyone's favorite valve covers?
Slo-Poc (04-20-2016)
Received 1,260 Likes
GMPP
ajrothm (04-07-2016)
neutron82 (04-07-2016)
More Proforms here.
But it will look much better when I get it back together now with AN's for crankcase breathing and wrinkle black.
Make sure to use some wires with the lowest Ohms that you can get.... If not, you'll run into misfiring issues under boost... The coils are just not strong enough to light it since they are over 3' away...so any additional resistance will add to the problem.
I used MSD super conductors for years, now I run the Taylor 25 ohm race wire and like it MUCH better. Taylor plug ends are 10x better then MSD.
speedz06 (04-23-2016)
They're pretty neat and the price point is nice. Only drawback is they don't take an LS oil cap. You have to use a SBC style one which is why I have that big ugly breather on one of my pics. Now I just fill through the AN. Also the rubber washers around the bolts get soft and start squishing out. Replace with nylon washers from the hardware store and all good.
Received 1,193 Likes
St. Jude Donor '15
I had that happen on the seat heater connector on my truck. The thing was melted.. common problem too. I replaced all the pins and connectors and it's been fine ever since, fortunately.
