Lsx or dart for 427 shortblock
Torn between the two. Should i go for a lsx shortblock or the dart shortblock. Probably going to max out my d1 that i have and throw a little dope at her when i need the extra power. All opinions will be very welcome, pros and cons of each, thanks guys
The old Next's require the oil pan adapter and remote oil filter and that main cap design didn't work out how they thought so they redesigned it to be like all the other LS blocks but I hear that new casting is not up to par.
Can't really go wrong with an LSX.
LSX, GM has way more R&D into that unit than Dart could ever accomplish given the size of the companies. The LS Next from Dart is relatively new while the LSX has been proven time and time again. If the goal is about 1000hp the argument for an RHS could be made because of its lighter weight.
I have no experience personally with ERL but many like them as well
Received 1,193 Likes
St. Jude Donor '15
Crack goes the RHS
Doing a lsx from cnc-motorsports. They build a ton of motors for the sprint car community and muscle cars. They are 1 hour away from me which is awesome.
Still in the planning phases taking the measure twice cut once mentality this go round
No major failures but Im seeing sleeve shift above 1500hp so that block has to go. I guess the fact that I keep blowing head gaskets has prevented a catastrophic failure
Im curious as to what direction you are considering going? LSX blocks are proven to hold your power level without issue and I haven't seen or heard of any core shift issues or water jacket failures since the revision in the blocks a while back. In my opinion the only other option better than the LSX block would be a Sleeved billet block...
Good read on the new setup:
http://www.enginelabs.com/engine-tec...ower-handling/
I know my little 388 LSN knocked down 1140hp without skipping a beat and had plenty of room to go with better heads/cam and smaller charger pulley.
5 Liter Eater (04-14-2016)
Looking through some Material science literature the tensile strength of iron is still higher than billet aluminum. Ill have to look up the exact figure
