RecMech LSX427 F1x standing mile build
#182
Received 1,194 Likes
St. Jude Donor '15
Just hangin out, nothing to see here
#183
Here are the exhaust mods.. It was miserable taking the system on and off with slip fittings.
ARH 2" headers, cut and added v-bands and 8 EGT bungs.
Cut and welded the mid pipe, added v-bands, removed the mufflers and ran 3" straight pipes. (the hangers and clamps at the tips are temporary, until I order a set I can weld on)
#185
Plan is.. If my Hi-ram ever shows up, to add 2 stages of dry nitrous and see what that does to egt after a mile.
#186
Nice to see relevant EGT sensors...
WB perhaps a bit too close to see not just (two?) individual cylinder(s)?
Anyway, better than nothing!
#187
Yeah spraying a **** load of n2o will cool the intake side off. Might add a few degrees to the EGTs though!
#189
same atv jack I use!! lol
#190
Some more updates.. Unfortunately it looks like this weekends mile and a half event is cancelled due to rain.
I have doubled up on the fire system. (2) 10 pound Firefox bottles. One is feeding 4 nozzles under the hood. The other feeds 2 under the dash and 2 over the stock fuel tanks.
A simple bracket hold the 2 pull handles.
#191
Dual chutes are required over 250 mph.. Also cut up a perfectly good wing from Carlyle Racing to meet our rules. I did add extra struts to the wing due to the speeds we run as well as the fact that we cannot run a wickerbill.
Chute mounts and push bumper. Dual release handles are in the pic above.
#192
St. Jude Donor '15
So badass
#197
I also have a 4" pulley to throw at it (from 4.25")
#199
