C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Dual spal vs stock fan
Old 05-13-2016, 10:15 PM
badass68
badass68's Avatar
Default Dual spal vs stock fan
I've read mixed reviews. Which one actually moves more air?
Old 05-13-2016, 10:29 PM
C6 Curtis
C6 Curtis's Avatar
I can tell you that my stock fan on blast and a 160* stat leaves me at 171* even sitting still in 85+ temps. I run my fan on a toggle switch... Oh and to add Im using the stock Radiator and im Turbocharged
Old 05-14-2016, 09:14 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Stock fan cools better than the standard dual spals that dewitts sells. Now if you are talking other spal setups like the dual D3E setup, that works much better than stock fan.
Old 05-15-2016, 02:55 PM
badass68
badass68's Avatar
The D3 setup doesn't look like it'll work with a blower.
I'm gonna try adding more shrouding to the stock fan so it pulls air over the entire radiator.
Old 05-15-2016, 03:38 PM
Detoxx03
Detoxx03's Avatar
Slo-Poc has the D3 setup on his car. Futral said it was a tight fit but they made it work. I drove his car around some to help break in his Mantic triple and I can tell you besides the clutch being amazing that the D3 setup really really works.
Old 05-16-2016, 04:52 AM
venomws7
venomws7's Avatar
D3's fans setup? What radiator?
Old 05-16-2016, 09:45 AM
badass68
badass68's Avatar
Interesting! Dewitts and Ragin Racing claim the dual spals move 40% more air.
Old 05-16-2016, 09:54 AM
Unreal
Unreal's Avatar
On paper with nothing in front of them in theory. Reality and theory are vastly different and once you put a restriction in front free flow numbers mean nothing.
Old 05-16-2016, 10:04 AM
badass68
badass68's Avatar
Are you using the 17" brushless?
Old 05-16-2016, 10:23 AM
Unreal
Unreal's Avatar
Yes I use the 17" brushless. It puts the standard duals to shame. Locals have started swapping to the dual d3 PWM and that works much better than the 17".
Fans in order of how great they work
D3 PWM dual
17" Nuova
Stock with wiring upgrade
Stock
Dual Spal 11"
Old 05-16-2016, 10:40 AM
badass68
badass68's Avatar
What do you mean "stock with wiring upgrade"?
I found this. Fully shrouded stock fan. Looks like it came on 05 C6 and 05-09 XLR's. Might be an upgrade.
Old 05-16-2016, 11:36 AM
Detoxx03
Detoxx03's Avatar
Stock radiator.
Old 05-16-2016, 12:06 PM
Nino S
Nino S's Avatar
I just went through a cooling project myself on my F1X/Z06. I ended up with a 17" brushless from dewitts on a shorty radiator. I also had a lot of aluminum ducting made to block off the side and top so it is drawing as much air as possible through the fan. My first choice was D3 but I was told that it was not set up to work with the short Dewitts radiator. We have had 2 weeks of rain until yesterday and it was only 65 degrees so I really cannot say it is all fixed or not but I never saw over 195 degrees after a pull so I am at least 30 degrees better then where I was with the dual SPAL fans from dewitts, the duals are a waste of money IMO.
Old 05-16-2016, 03:16 PM
lt1z
lt1z's Avatar
I haven't had any issues with the stock fan and a 160 stat in my aluminum block SC engine. With some iron block applications that D3 fan will help out since they tend to run hotter.
Old 05-16-2016, 09:07 PM
Unreal
Unreal's Avatar
Factory with wiring upgrade=ditch the PWM controller and run a direct relay power source. It allows the fan to move more air.
greatgonzer (06-22-2016)
Old 05-16-2016, 09:19 PM
0D3PE
Former Vendor
D3PE's Avatar
Its all about CFM moved with the restrictions in front of the fan (radiator/condensor/intercooler/etc, thats why our fan setup works so well since we use the extreme duty Spal fans, the other reason it works well is we shroud the complete radiator surface area. Our setup is also 100% plug and play and fan speed can be controlled through the factory ecu still! Also with our fan kit we haven't had to upgrade any radiators, OEM cools perfect!
Our original thread:
https://www.corvetteforum.com/forums...d-control.html
Old 05-16-2016, 09:53 PM
badass68
badass68's Avatar
So, the pwm controller doesn't run the fan at 100% full power?
To Dual spal vs stock fan
Old 05-16-2016, 10:01 PM
Unreal
Unreal's Avatar
That is correct.
Old 05-16-2016, 10:04 PM
schpenxel
schpenxel's Avatar
Received 1,193 Likes on 1,052 Posts
St. Jude Donor '15
90% is generally the max.
And the stock wiring is pretty small. I saw something ECS had posted about by just changing the wiring they had a significant difference in airflow--enough to avoid having to do any other cooling mods on a car that was running too hot and was about to get a round of cooling system mods, for whatever that is worth.
Old 05-16-2016, 10:15 PM
Unreal
Unreal's Avatar
And even then, 90% isn't the same as direct from battery/alt.
Quick Reply: Dual spal vs stock fan
