Instant crankcase pressure relief.
#42
http://www.mightymousesolutions.com/...b-4fbb1b3a8cf8
My only 2 questions.
1) Would I be better off welding a AN fitting on to each valve cover in a location that is baffled or just run the AN adapter that goes to the oil filler as shown.
2) With the AN adapter going right to the MM can, will if pick up exes oil because there is no baffling or screen to prevent it from sucking up oil at high RPM. I don't want to be emptying the CC all the time.
I just want to do it one time and be done.
I would like to ad that I was at Summit raceway today. There was a boosted Z06 running a different style system. He did have the MM boosted breather on the oil fill hole with out the elbow. The breather was on an angle. He said he's had zero issues with oil splash or anything. It looked clean and dry.
I still want to improve my system completely.
David@MMS (08-28-2016)
#43
#44
Supporting Vendor
It works very well as laid out in the system. I expect you to be very pleased.
I currently do not have a MM can and feel that my set up is in need of upgrading. I am just going to go with the Z06 WILD set up and be done.
__________________
Solutions for the common gearhead #made in USA
facebok.com/mightymousesolutions
#mmsolutions
Six time NMCA True Street Champions
Home of the first Twin Turbo C7Z 7.81 @ 176
3470# Stock bottom end and heads Corvette Stock Bottom End Record Holder
#mmsolutions
#45
Good to hear that you're now offering complete kits! What's the hp capacity of the Z06 Wild?
#46
Supporting Vendor
-still filling in this page of the site
http://www.mightymousesolutions.com/...-systems/cvkfz
example of ls7 wild routing
example of c5/c6 base 'wild' kit
-custom systems up to 1500hp per can
JetstreamGS (08-31-2016)
#47
Thanks David, I recived the C6zwild kit today. Looks great and fits great. I just replaced my rear cover seal due to a leak that I'm sure was a resolt of inadequate ventalation. Although my old systems can really never had much more then a shot glass of tramp oil that doesn't mean it was working properly.
I trimmed the vent line a little shorter then I'd like and will add an inch or two, tomorrow. My error.
Feel free to use the photos if you wish.
I only have one question or concern. With the stock LS7 valve cover will I be filling the can fast due to splash oil of the rockers? The stock cover has no baffle at the filler cap. Should I add one or run a differant cover.
Just trying to foresee any improvements that I should make now.
David@MMS (09-06-2016)
#48
Supporting Vendor
thanks for the pics! I find no increase in can filling based on that location, but feel free to keep an eye on it and let me know.
GeneSch (09-06-2016)
#49
Gene does the filler cap on the dry sump engine just screw off or did you remove the valve cover to get it off?
#50
There is a small tab on the inside. I popped the tab off when I powdere coated them. I would recommend removing the cover to take it off. This will prevent the tab from falling into themotor. It is really easy to remove it.
JetstreamGS (09-07-2016)
#51
UPDATE......
I put about 250 miles or so on her and there is not a drop of oil in the can. I did check to be sure it was in fact working. I will hit up the drag strip tomorrow if we don't get rain and put her to the test.....
Wish I did this last year. Would have save a lot of time and money.
#52
i also wish i had done this earlier. my previous catch can setup was stupid and a waste of time/money. I wish I would have known and just gotten this one from the start.
the reduction in fumes smelled while cruising around is dramatic when compared to my old just simple and open Moroso catch can. that alone is worth the price
David@MMS (09-16-2016)
#53
Its amazing how many people waste money on other setups first, to finally land up with a solid MM setup that just plain works.
David@MMS (09-15-2016)
#56
Just had the car at the track and not a drop or oil in the can, no oil smell and I didn't blow any of the seals out again.
#57
Amazing huh. MM FTW.
Seen way to many other people blow seals with other options. Its sad.
#58
Yup. My buddy was blowing seals out constantly. I have never had an issue running MM cans. There are some products that just work, and looking elsewhere is silly.
#60
