C6 cooling issues need suggestions
Ya I've done the track spec triple vent to the hood it helped some but not enough at dead still. The fans I already have are pullers so I'd have to either buy pushers of put then on the back of the intercooler
I spoke with Don meziere very nice guy. He thinks the issue is probably more to do with recirculating the hot air than actual water flow. So I'm considering a second or radiator in the rear or moving my current radiator back there.
I called D3 today regarding the direction I want to go with my radiator/spal setup and they told me that their fans are not brushless. Just wanted to clarify.
I know this sounds silly and I think we have talked about it in the past, but have you tried running distilled water and water wetter? I was hitting around 243-245 in boost and around 230 at 80mph cruising on a 100* day. After doing the full flush, adding 100% distilled water and adding two bottles of water wetter, the highest I have seen after a hit is 215 and heat dissipates super fast now.
What's crazy is that at speed or while driving the car will cool down. Which I know shows that air flow is an issue. But sitting still running if it gets to 230 I can put it in neutral run it at 2500 rpms for 10 seconds and it'll start dropping temps not alot but a little. I don't think a fan set up is going to help those spal fans I have move a ton of air and we have a good shroud.
Yes it's pure distilled water and water wetter. The more testing I've done this evening I've found that I don't believe increased water flow will help. I think I need to figure out how to get more air to the radiator for it to be able to dissipate the heat. I really think relocating it is the best option. Still considering adding fans in between condenser and intercooler. I just don't know if I want to cut the rest of the cross member out to get it in there.
But AC was still ice cold and didn't shut off???
#34
you can move the intercooler in front of the bumper to remove the restriction of air flow to the radiator, there is a thread that has it done somewhere. You can get a set of brushless fans from dewitts.
Look near the bottom of this thread.
https://www.corvetteforum.com/forums...t-build-8.html
