Custom charge pipe advice
#61
Pipe
OK SO WHAT WAS THE OUTCOME OF THIS pHIL,,,DID YOUR SET UP WORK OUT...
I JUST DECIDED TO ADD METH TO MINE AND FABD A NEW CHARGE PIPE AND WANT TO KNOW YOUR LESSONS LEARNED FROM THE MAF LOCATION..HERE IS MY DESIGN - UN TESTED YET. I HAVE ABOUT 4-5" FROM BEND
#62
That looks really nice BTW but either you have super large hands, or that's a 3" OD pipe which I expect to have higher velocities and smoother airflow than the 4" pipe so you might not see any of the usual MAF/SD tuning issues on the low end.
As for my current setup, the maf flap I played around with to force air into the sensor at low velocity and then move out of the way at higher flows worked pretty good but I wound up sliding 65 3/8" bendable plastic tubes down the 45 degree elbow between the IC and MAF sensor...sorta like a super straightner 12" long. There's a #4 stainless mesh screen on top of the IC outlet to keep the tubes from falling down into the IC and another screen to keep them from getting sucked into the motor but they're bent and packed in there tight and not going to move.
Did this 2 months ago and now can run MAF only. Idle and low end seems to be just as good as SD only but haven't taken it into boost yet to see what happens. Going to replace the plastic tubing with 3/8" thin walled stainless next week and hope the stainless works as well.
#63
lol,,its a 3.5" dia pipe ,
,,i was gonna say plastic tubes ? agianst the pressurized heated air..? i agree ssteel tubing would be much better..can you post a pic of what those looked like i mean are they attached to the walls of the charge pipe bend ? or within the tubing..
#64
Here's a pic of my first pass stuffing the elbow but using smaller stainless tubes. The tubes stick out the other end of the elbow equally and I machined the ends flat and got rid of the bell mouth caused by the tubing cutter. This worked great but felt it was too restrictive and moved to 3/8" plastic which was a lot cheaper for testing. Don't post many pics due to trolls and swinging dicks on the forum but will post a final version using the larger stainless tubes in a week or two if you're interested, along with a scan of MAF output frequencies before and after.
#65
ohh wow..nvr envisioned that,,,yeah please keep us updated,,i love home grown project testing.....il be testing mine in about a week and will report back here ..maybe we will exchange notes and come up with a great design..
#66
This is a 4 inch pipe with MAF, IAT, and meth. The maf frequency is very smooth and everything works perfectly. I had the same setup with 3 1/2 inch and it also worked fine up to a certain power level.
#67
Interesting thread OP, and props for your fab'ing skills. I've had my share of FI vehicles, but none were LS based. I know these MAF's are touchy to turbulence (own a C6Z)....but the 4" inlet pipe reminded me of LPE's 100 mm MAF sensor. It would be a $300 experiment, but I wonder if there's any merit in testing it? Forgive me if this has been beaten to death in here, but I've rarely come across a mention of this (non-GM) MAF unit...and it was designed primarily for FI applications. How well it functions, I honestly cant say I've seen a review.
I know TSP also has a 100 mm MAF housing (for a GM MAF sensor though), but it comes with a honeycomb insert, which I was reminded of when seeing your straightener. Again, not inexpensive though at $270. I assume that honeycomb material is commercially available in some size of sheet somewhere though, as honeycomb inserts in MAF housings have been around forever...and might be easier that stacking individual thin wall tubes?
Either way...look forward to hearing the outcome.
#68
My maf has zero turbulence on my custom upper pipe.
#72
Update
So today i installed the charge pipe and im happy to report that the engine is taking it in just fine idleing at 950 rpm and no rough idle or engine light..next week its the dyno tune
#73
Glad it's working for you. I think the MAF turbulence problem is somehow in the ECS "standard" airflow system. No knocking their product, but I haven't heard of anyone using either Procharger's and A&A's IC having any problems. Could be the shape of the IC, inlet vs outlet locations or size differences, BOV locations, etc.. It's easy enough to understand the flow dynamics with the BOV closed and a lot of air moving through the system under pressure but who knows whats happening at low RPM, low flows and static pressure with the SC still providing air but some of it going in the motor, some of it going out the BOV, etc, flow differential across the IC, etc... Add in a healthy cam that varies 50 RPM at idle and the SC impeller varying almost 5 times "faster" and airflow has to be pretty ragged by the time it gets to the sensor. Did the exact $14 honeycomb MAF screen shown above, moved it forward, moved it back, added another one in, results were....meh
Stuffing the post IC elbow with tubing has shown the best results, just not sure if it's because of straightening the air or decreasing the air flow which raised the velocity and I haven't taken to high boost and RPMs yet until I move to 3/8" tubing. I can also smooth out and "filter" the analog input in the MAF before it gets converted to a frequency but that will slow the response tie a bit
Not that I'm obsessed with running MAF, just trying to figure it out during the off season. Keeps me away from looking at the BTR388 and other things I'd like to do to the car.
#76
results
happy to announced that the on-off charge pipe was dyno tested today and performed flawlessly,,no turbulence of any kind, no leaks, no nothing..just worked out perfect..the meth plus a pulley gained us 60 rwhp..lmk if interested on the pipe...thinking about selling them built..
#77
#78
