For Eforce HX upgrades
Im wanting to add a larger coolant reservoir as well as l see many like to use the Magnusun HX which looks pretty good to me but the D3 setup with new higher output circulation pump, larger double reservoir and big HX seems very nice.
Wondering if that bigger HX will block airflow like the centri intercoolers are known to do.
Wondering if anyone has any feedback or info about upgrading the eforce
subsystems.
Thnx
subsystems.
Thnx
Man, so much activity for the other brands I have to say, to do over again I would not get the eforce setup. I know they sold allot of them in the beginning and love the Eaton chargers, have had a few before this on both GM and Fords but it is just the limited packaging here on the vette kit that falls short. The car is fun but lacks the consistent performance and the snap of the maggie kit IMO.
You can search for some of my older threads about what upgrades I tried for the eforce. I upgraded the pump and reservoir but not the IC. I had very good and consistent results with the eforce. Not sure what you are experiencing from your post.
He's gotten 780WHP and 14psi out of a E-Force on a built 402 with an A6 trans, which typically dynos significantly less than an M6. No one is probably ever going to get that kind of boost or power out of a H-Beat C6 system, which is what I'm running, simply because that system, with the C6 accessory drive, is limited to ~8.25" HB/lower and a 81mm/3.2" upper, which limits boost (on a cammed LS3) to around 12psi.
The Magnuson H/X is supposed to be an upgrade, and a fairly cheap one at that, so I would try that. The D3 system is very nice, and all their stuff is high quality without a doubt, but that comes with the consequent high price tag.
If you're looking to lower IATs, you can also add an expansion tank in the batt box (if your car came with a front mount battery), use high flow fittings and -12 hose and insulate the tank and the hoses well. I have seen very good results from doing that on my HBeat setup, even with the standard Bosch pump. Not sure if it makes that much of a difference on the E-Force, since their H/X system seems to have a better flow through routing system on the reservoir to begin with.
BTW: in my view - and I've been studying this lately - the E-Force pulley system is also much better than the H-Beat, because it adds a second mid-height idler for better belt wrap on the Lower pulley and they now have a HD sprung tensioner system, whereas us H-Beat guys are stuck with the flimsy-*** stock spring tensioner. I'm right now looking into whether I can get the parts to duplicate the Edelbrock idler/tensioner system on my car.
The following 3 users liked this post by CI GS:
OP, Listen to this guy^^^^^^.
Hey guys thanks for the replies. I think that I need to get my tune straightened out but power is pretty good.
Im about to pull the trigger on the D3 setup because of the larger front mount reservoirs. Even a larger reservoir seems to cook under the hood with the LS7 in traffic so moving it out might be a good idea.
Im going to look back at realcanuk's posts also.
Dedicated Motorsports fabbed me an expansion tank for my ZR1. It only adds a little over a half gallon to the system, but the placement is great. I can drive the car as long as I want, stop, pop the hood, and place my hands on the tank. It never gets hot.
Now that looks nice. I dont mean to sound simple but as expansion tank does that mean that the original reservoir (or tank) stays and this is added, or is this replacing the original? Does Look like a great location.
Yes sir. It is in addition. The idea is to increase the system volume (by adding more coolant capacity).
