stock ls3 shortblock
I read that 550whp on boost is about the max you want to be at for "safe" conditions? Is that true?
I want to try and crack a 130mph trap speed... that's the goal. The car makes 453whp on a Mustang dyno on a VMS 2.5 Cam only setup.
It's a M6, stock rear and transmission.
I was thinking about going FI to reach my goal. Most likely supercharger (although turbo is tempting). Just not sure how well the short block handles that type of mod.
I went 10.63@137 leaving soft on a stock (even stock cam) LS3 with a rear mount single turbo setup. That was a 6.9@105 1/8. Added a cam/meth and went 6.66@111 in the 1/8 with same tight converter. Didn't run 1/4 with it. This is an auto car too.
So your MPH goals are gravy with a good tune and forced induction.
Thanks for the info! Something to look forward to now!
See signature for your answer.
With octane I have no issue running ~800rwhp out of a ls3.
People have made 1000+.
With straight pump gas ~600-650. With e85 or meth, 750-800.
Platinum Supporting Vendor
A&A V3 Ti-trim Kit 3.6" pulley
AlkyControl Meth kit
Headers
Goal will be accomplished and then some. And still be well within the "norm" for LS and boost.
Headers
Thanks for all the replies. Very helpful!
The car already has a VMS 2.5 cam in it. Moderately sized... not sure how good it'll work with boost though. Made 453whp on a Mustang dyno.
Making 600-650whp would be pretty sweet though!
Received 1,194 Likes
St. Jude Donor '15
Only 870 on a stock LS2? psst.
St. Jude Donor '15
How much timing & boost were you running?
I'm at a tad over 800 peak @ 12psi (peak) out to 6700. Forged bottom end. however, stock ls3 block. As far as i understand, getting the block prepped to survive is a big deal as things tend to flex with these ls3's.
I trust that Sam@AMP didn't have the timing or the tune off from what works best for power and longevity. Since the part was a rod failure, doesn't seem that detonation was the problem regardless.
