C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
COMPLETELY NEW STYLE SECONDARY DRIVE now Available
Old 11-01-2017, 09:00 AM
  #61
schpenxel
schpenxel's Avatar
Received 1,193 Likes on 1,052 Posts
St. Jude Donor '15
Am I missing something? I don't see anything adjustable in that pic
Old 11-01-2017, 09:14 AM
  #62
neutron82
Support Corvetteforum!
neutron82's Avatar
Received 1,260 Likes on 1,055 Posts
the bracket is 2 pieces, the part with the idler on it pivots side to side... look just below the idler and you will see the slot
Old 11-01-2017, 09:15 AM
  #63
Garmans12valve
Garmans12valve's Avatar
maybe the entire bracket moves but I don't see it either.
Old 11-01-2017, 04:07 PM
  #64
schpenxel
schpenxel's Avatar
St. Jude Donor '15
I see it now
Old 11-01-2017, 09:41 PM
  #65
Monte4ever
Monte4ever's Avatar
The outside bracket moves side to side on the slot under the pulley. Looks like that lower bolt is for a wrench or socket so you can have something to grab onto while adjusting tension.
Old 11-01-2017, 10:05 PM
  #66
neutron82
neutron82's Avatar
that's exactly what it is, the bottom bolt is just there to get a wrench on to add tension just like the j-bracket on a&a's blower bracket... you can see how much adjustment is left and it's more than enough
Old 05-12-2018, 07:31 PM
  #67
BoostedOne
BoostedOne's Avatar
I'm curious as to why the design changed from an auto tensioner on the jackshafts 4 rib belt to a manual tensioner.
I currently have the manual style but have had to tighten the belt twice and it still makes noise on startup.
I've noticed my bracket has the provisions to move the jackshaft down and install the auto tensioner but don't want to do so if their was an issue with that design.
Old 05-15-2018, 07:08 PM
  #68
Josh@AandASuperchargers
Platinum Supporting Vendor
Josh@AandASuperchargers's Avatar
There was fitment issues on C5s if we used the auto ten., so we changed it early to the slide ten. style. We prefer the slider cause you can get whatever tension you need on the belt.
Old 05-15-2018, 07:26 PM
  #69
ysb02
ysb02's Avatar
does the noise go away after you’ve run the car for a bit? Having noise issue on my c5 setup
Old 05-16-2018, 01:50 PM
  #70
Monte4ever
Monte4ever's Avatar
Did you check for proper belt alignment? Mine is quiet like stock.
Old 06-01-2018, 05:39 AM
  #71
07blkvette
07blkvette's Avatar
I have belt squeal on start-up also. I have been trying to fix the problem for a while now. I'm not having any luck. I'm thinking it's the accessory belt tensioner. At least I'm hoping that's what it is.
Quick Reply: COMPLETELY NEW STYLE SECONDARY DRIVE now Available
