dying need of help with blower cam
i have an 08a6 ecs1500 with alky injection and headers. Im currently looking to add a cam to it and need help on whats the best cam to go with. i made 610rwhp and im trying to get as close to 700rwhp as i can. any proven cam/cam packages out here, that someone can point me to .
I have a CCP Jam Cam with my YSI setup. Haven't gotten it on the Dyno yet but it idles smoother than my BTR stg2 turbo cam did that I used when I was turbo.
Received 1,194 Likes
St. Jude Donor '15
Contact someone like Pat G and have him spec you one. It's like $25 and you can have it ground by cam motion in a week or so.
Yes they are, best way to get I. Touch with them is through e mail. Then they can get you on the phone and choose the right custom cam for your setup and goals. Futralmotorsports.com
Originally Posted by dnrox
How much do you want for the cam and how many miles on it?
Thanks,
Dave
Thanks,
Dave
Cam motion
My last dyno was 722rwhp and 654rwtq on a vortech t-trim @ 9psi... Pulleying down next month plus CNC heads to try and get over 800rwhp; probably be somewhere around 14 or 15 psi with newest pulley...
Platinum Supporting Vendor
Most common blower cam we run is 220/230 116 LSA .590"
Easy to tune, easy to drivein traffic, makes power across the board.
If someone wants some chop to it though I recommend the Arun Jam cam which Brian Tooley stocks. Requires a little more experience for tuning, but still very usable. I've made 900+ rwhp with that cam and Ysi setups.
Naturally Vain (09-09-2018)
St. Jude Donor '15
220/240, .598/598 117 here.. pretty close to what you guys run
St. Jude Donor '10-'11-'12
With the A6 trans you have (I assume stock converter) you will not be able to go too big on the cam without getting some surge at idle. If you had a higher stall converter, you could go with a bigger cam and not have the surge issue.
Something like what Josh recommended is what I had when I had an A6.
Josh@AandASuperchargers (02-03-2017)
Former Vendor
PM sent
