Traction issues. BEST 17 inch Tire for 1100whp??
What kind of 17 inch tires are 1000 whp vettes using for the best traction at the track and street ?
Video of my car last week at the track posted below . I was only able to get one pass so i wasnt able to get much testing and tuning done . This was also my first pass on the new setup .
https://www.youtube.com/shared?ci=TdgFid3rVsE
I have used the m&h 325/45/17 and it's ok when fresh but now I have the 305/45/17 MT R and it's an improvement but definitely gives up high speed stability if you like high speed fun.
I'd warm them up a little more as well, that's a 17x12 correct?
At the track, the discontinued 26x11.50x17 MT ET Street Bias Ply seemed to work well if the prep was good.
A Hoosier 28x10x17 slick also works well.
What tire were you using?
In my experience, a high horsepower manual transmission C5/C6 requires a bias ply tire to be successful at the drag strip. It also takes just the right technique with the clutch and throttle during the launch.
Fast forward to the 0:50 mark of this vid to hopefully get an idea of what is going on during the launch. The 60 foot was only a 1.58 on this pass, but it was enough to get the job done. With more practice another tenth could probably be shaved off the sixty. There are vettes going even quicker, but I was still using a stock trans and diff at the time and needed to drive it back home.
Maxspeedsti (02-02-2017)
Here's one from outside the car. This was a 1.54 short time but I messed up on the 3-4 shift.
Do you ever make it to SETX? I live near Beaumont and still have those tires. They are a few years old but only used at the track and always stored indoors. You can have them if you want to come and pick them up sometime. I took them off to switch to the 28" slick.
sevinn (02-02-2017)
Wow that's a really nice offer thank you so much. I'll have to see if I can make some time when I go visit the family in Lake Charles here soon
Here's one more with a 28" tall Hoosier slick. This was after being away from the track for a couple of years and the boost controller turned off.
With an 18 inch drag radial on the runway, I can plant 13psi in 3rd and ramp it to 18 psi. Also, 4th seems to hook ok at 18 # of boost from 130mph to 165 mph. I'm looking to add another 200rwhp and trying to determine if the 17" ET Street R would work better than the 18" ET Street SS. They are both 28 inches tall.
