SINISTTERC6 awakening the demon
#181
#183
#184
#187
Keep the updates coming!
#189
Turbo and hot side coming together
Began charge tube fab
100 millions more projects underway, stay tuned
#190
Any updates??
#192
Bunch of updates
Fuel pump was determined be spun too fast by oil pump and aerate the fuel/ explode. Rather than exploring a cam driving fuel pump a Holly VR2 with a kenny bell booster was chosen. Old parts sent to Waterman and awaiting new pump to arrive to be installed. Fuel tank/ Lines/ Filter all complete
Pipes fabricated for turbos sit too low to the ground as round pipe was used in the bends (a third party fabricator was hired for the job, he was given pictures and informed to provide as much clearance as possible), fabricator made aware of the problem and offered to redo the setup at a 50% labor charge as he states he was never given explicit instruction to use an oval pipe. The Mechanic working on the car will weld in the proper oval pipes to gain back 2 inches of ground clearance.
Turbo side exhaust will need to be redone, they don't sit center in the quarter panel openings
Tanks and coolers were mounted for turbo oil and coolant
Air tank mounted for boost control
Things still to do:
Mount power steering
Plumb drysump, install remote filter
Plumb turbo oil and coolant
Finalize wiring harness
Rebuild axles
Install direct port Nitrous/ Meth
Things still to do:
Rebuild axles
#194
Thanks for the update! I enjoy the build
#195
Hmmmm...interesting. First time stopping back into this thread in a while. Definitely curious to see how that turbo location works out in regards to exhaust pulse/distance etc. Also, I'd be VERY concerned with what those f'ers are going to pick up from the low pressure area under the car from the tracks surface. Just my internet $.02...
- Travis
- Travis
#196
More updates
With all of the pipes now being ovalized they tuck up much closer to the body, there is one section which dips about an inch below the frame but this was the best that could be done given the size of the Garret turbos. Next having to redo the side exit exhaust, will have pics when that's done
#198
Looking good!
#199
It was exhausting but all pipes now welded, painted and wrapped. Onto plumbing and the engine bay.
#200
As always thanks for the updates! Think it’ll be ready for spring?
