Vortech V-7 YSi RWHP?
I'm about to start a build thread soon after the build is reaching its final stages. Right now I have a Vortech V-7 YSi going into a c6 ZR1. I was wondering if anyone has a similar build and can give me an idea of how much the YSi can put out? I'm hoping to be able to make at least 1k+ RWHP.
Basic rundown:
RHS 427
RHS Pro Elite heads
Vortech V-7 YSi
I plan on running e85 and 93 occasionally
Basic rundown:
RHS 427
RHS Pro Elite heads
Vortech V-7 YSi
Ahhh I love this. A centri ZR1. Only other time I've seen it done was on Forza when me and a friend would do it. Looking forward to seeing how it turns out. 1K is easily doable with a YSi.
Never finished the car. Car made 832rwhp @5000 rpms on a unlocked converter. Methanol was spraying the mass sensor and causing the car to pull timing. Was in the middle of fixing it when i got a deal on the f1x.
BrandonLS9 (02-28-2017)
To answer the question, 1000 is cake. Even a basic basic not spun hard ysi can make 1000+ with ease. 1100 isn't hard. 1200 is possible with a well sorted combo.
You can make 1000+ on an auto with a 3" or 3.1" pulley.
Joe@CPR made 1050rwhp on a stock ls9 block, ls9 heads, ls3 intake super basic easy combo and was only limited by fuel. No meth, out of injector. No fancy big motor, nothing fancy at all. Nice budget build and 1050 first time on dyno and only reason he stopped there was out of fuel.
Has anyone been able to make 1000+ on 93?
I made well in excess of 1100rwhp on 91.
Were both of these on straight pump gas or meth injection also?
OP, please keep the updates going. I know there are lots of people interested in how the MSD intake holds up at 30+ psi.
YSi will get you 4 digits.
Made 1116rwhp on 9 degrees with 91+ meth. Error'd out dyno on 14 degrees. Made 922rwhp no meth. So not meth dependant to run, but meth dependant to make 1000+ on 91. Now with flex fuel, not so much.
