D3PE Dual Fan Setup on A&A Z06
Does anyone have any experience with trying to fit the D3 dual fan setup on a z06 with the A&A T trim? Thanks for the help!!
I'll bet the guys at AA or ECS would have seen it if it has been done. They see tons of combo's. the D3 guys may also know. If you do buy it, make sure you properly seal the shroud to the radiator there is a big space with the dewitts.
It's not a Z06 but Slo-Poc runs that fan setup on his car with an A&A kit
I messaged D3 on here and no answer yet. I'm sure it could be made to fit but I wanted to see how bad the modifications need to be. Otherwise I'll have to build a similar setup from scratch to fit my setup.
Call them. It's also not D3 anymore. They stay very busy and aren't vette focused, but build in house, awesome products for different platforms.
Platinum Supporting Vendor
We did one in-house on a '12 GS Auto with our A&A kit. It required some cutting/grinding/bending but we go it to fit and the cooling was much improved over the stock fan setup.
If only they could shift the location of the 2 fans so that the passenger side fan sits low instead of high it might have been a drop in mod.
I have the D3 fan setup, however I am using the ECS kit, not the A&A kit. I might be able to answer with my experience. Similar but different.
