Not bad for pump and meth through the A&A Filter
Should be a fun ride.
small blower cam
91+meth
14 psi peak
small blower cam
91+meth
14 psi peak
Received 1,194 Likes
St. Jude Donor '15
Peak HP RPM?
Holy hell, 14psi on what pulley? I just went down from a 3.8 to a 3.125 and I made ~700 on 6-7psi(on the 3.8) I have no clue what I'm gonna make now.
This is a 2.85 with an 8" lower, flip drive 8 rib setup. Engine is not a stock LS7 though. That pulley combo would make a lot of boost on a smaller motor.
If you have the fuel on a 10.0:1 LS2 I would run a 3.47/8.0 to start. That will be about 10,000 rpm below the V7 limit. I would expect that pulley combo to make 16 psi or so.
