C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Can Dashlogic display injector duty cycle?
Old 04-20-2017, 10:45 AM
Wilkinshc
Wilkinshc's Avatar
Default Can Dashlogic display injector duty cycle?
I see injector pulse width but I don't see duty cycle? Can you add a formula and if so does anyone have it. I am guessing it is injector pulse width divided by (120/rpm), right?
Old 04-20-2017, 11:02 PM
Wilkinshc
Wilkinshc's Avatar
Can anyone tell how I would type a PID calculation expression to show: Injector Pulse Width divided by (120/RPM). Would this be right? (pid(1008) / (120 / pid(10)) )
Old 04-21-2017, 08:21 AM
schpenxel
schpenxel's Avatar
Received 1,193 Likes on 1,052 Posts
St. Jude Donor '15
I'm not driving the corvette so I don't have dash logic with me, but yes, it can display anything you can pretty much come up with a formula on. Inj duty cycle is pretty basic.
I can look up the formula tonight if you still need it.
Try what you've got and see what it does. Not going to hurt anything.
Old 04-21-2017, 10:46 AM
Tech
Tech's Avatar
IDC is a calculation based upon Inj PW, so it's not quite as easy selecting something from a dropdown.
Old 04-21-2017, 10:51 AM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
He clearly knows that, thus the reason he's asking for the formula.
There's no reason Dash Logic couldn't add it to the drop down list if they wanted to. Boost, for example, is calculated, and it's in the drop down list
Old 04-21-2017, 10:57 AM
Tech
Tech's Avatar
Indeed.. got lazy with this one
Old 04-21-2017, 12:54 PM
Wilkinshc
Wilkinshc's Avatar
That formula didn't work. It gave me a number but it went to 100% at part throttle, so I must need to move or adjust something. I will keep working on it but it you have it would sure appreciate the help.
Old 04-21-2017, 02:07 PM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
I have some alerts setup for it already so I've got it. I'll look it up tonight.
Old 04-22-2017, 02:18 AM
SlowBusa08
SlowBusa08's Avatar
is there an extra space behind your parenthesis at the end? I didn't check the pid # but that expression looks right,
IPW/(120/RPM)
Old 04-22-2017, 11:57 AM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Inj PW by default is in milliseconds and RPM is of course in revolutions per minute. The / 120 part is getting you to revolutions per second (x 2 since you have two revolutions on a 4 stroke to inject fuel), so it's still seconds vs. milliseconds IMO
I'm apparently not using inj duty cycle on mine. The alert I had set was for fuel pressure, not duty cycle, so I don't have the formula in front of me.
You're close, it's just a matter of moving some decimals around now it looks like.
Old 04-22-2017, 12:43 PM
EnviedC6
EnviedC6's Avatar
The expression would be PW*(RPM/120), which is the same thing as PW/(120/RPM).
Old 04-22-2017, 02:00 PM
Wilkinshc
Wilkinshc's Avatar
Thanks guys ill try that.
Old 04-22-2017, 04:06 PM
RPOWU8
Support Corvetteforum!
RPOWU8's Avatar
(pid(10)*pid(1008)) /1200
(rpm*ms)/1200
Still need to double check by logging but I need to replace an idler pulley that's making alot of noise before I can drive it around.
DJ
Old 04-22-2017, 09:42 PM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
The divided by 1200 one should be right. Have to go from seconds to millisecond then x 100 since you want percent so that cancels out 2 of the 3 decimals
I'm going to try it on mine tomorrow also
Old 04-26-2017, 02:58 PM
FNBADAZ06
FNBADAZ06's Avatar
subd
Old 04-26-2017, 06:02 PM
Wilkinshc
Wilkinshc's Avatar
Originally Posted by FNBADAZ06
subd
Sorry, what does that mean?
Old 04-26-2017, 06:08 PM
Tech
Tech's Avatar
He wants to be notified of replies. Short for "subscribed". You can sub to a topic without posting, but some people (like me) look at recent threads you've posted in on a regular basis.
To Can Dashlogic display injector duty cycle?
Old 04-27-2017, 01:28 PM
ls1wolf
ls1wolf's Avatar
FYI - I've tried just about every combo listed above and nata...
If anyone has any ideas, I'm listening. IDC would be great to see.
Old 04-27-2017, 01:41 PM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
[injector PW in mins] x [RPM] / 2 * 100
This is the correct formula.
Inj PW will report in milliseconds though so you have to do that conversion (divide by 60000)
Try
pid(1008)/60000 * pid(10) / 2 * 100
That's assuming pid(1008) is inj PW and pid(10) is RPM which I'm not 100% sure of without checking
I'll play around with it when I get home if that doesn't work
Old 04-27-2017, 01:50 PM
ls1wolf
ls1wolf's Avatar
Try
OK, I did realize that you need to use "{" and not "["
But do you leave the spaces? Its still showing the formula ....
I must be lost.
Quick Reply: Can Dashlogic display injector duty cycle?
