Fuel system for e85 and boost
Who here boosted on e85? I have the stage 1 a and a fuel system with a z06 in tank pump, kenne belle bap, and 80 lbs fast injectors. Not sure if this will be enough fuel for e85 and wondering what you guys are running.
Car has cam, v3 si blower, and 3.6 inch pulley so about 10 lbs of boost. Adding meth and going to go e85 at the same time.
I am but I run a Fore triple pump kit and ID1300s.
You can upgrade the pump on the a&a kit, but they rate it with the BAP to 1,000 so I don't see much of an issue. The UPP kit I run is pretty much the same thing with a bigger pump. I took my BAP off but it's easy enough to put back on.
Received 1,194 Likes
St. Jude Donor '15
I'm using Z06 Pump, DW350il on hobbs switch, ID1000's and still have M10 or M15 (can't remember which) meth nozzle spraying. Not boost referenced regulator, but that would be the next thing I'd do if I'm maxing out injectors. Flex fuel sensor and usually run around E78 from local gas station
Not sure how much power but mods are in sig
I've seen 95% inj DC in cold air but usually don't see that high except during the coldest part of the year
Fore triple with ID1300s.
You should be fine to support anything the Si can put out on e85 fuel pump wise. Injectors might be a bit small. Throw some 1000s or 1300s in there and you will be fine (assuming the z06 pump doesn't die).
