Crank pulley pinning
Hello,
I pinned the crank but the pin is a little loose to where I can pull it out with a magnet. Will this work or do I have to re pin it?
As long as it it covering the crank and the pulley it should be fine. You can put some locktite on it to keep it in place if you want otherwise the crank bolt will keep it in place.
Received 1,193 Likes
St. Jude Donor '15
I'd go with it.
Although the loose pin will be jammed tight the first time it tries to spin, so that will probably be just fine also.
Or just do this:
