HPR -TT LSx build thread -
please explain how a crank machined from a forged "billet" is stronger than a forged one. this is contrary to my understanding, that the directional grain flow makes a forged part stronger.
Former Vendor
The other would be how it can be made. Since a raw forging does have some limitations, you can make the billet piece into anything you want to add or remove material were needed to make is stronger, lighter, heavier...what ever the case may be.
Received 1,194 Likes
St. Jude Donor '15
That fuel pump looks serious! (along with everything else for that matter)
Former Vendor
Here you can see a similar pump used on a vintage funny car.
http://www.eurodragster.com/news/fea...g_23_large.jpg
HP RESEARCH (08-25-2017)
St. Jude Donor '15
What’s the lever on the pump do?
Former Vendor
St. Jude Donor '15
Makes sense. That thing has to be moving a lot of fuel
Former Vendor
Former Vendor
Any of the Ti valves are going to be coated no matter what so that helps a lot. Generally there is going to be either a bronze liner or a Beryllium-Copper liner, which is what we used in this one on both the intake and exhaust. Mainly we went that way to help dissipate heat.
Petraszewsky (08-29-2017)
#33
Why not run the Jesel bushings on the lifters? We run the same set up in my car, it was advised by jesel to run the Amco-45 bushing from them, so that has a .060 hole drilled in the bushing helps keep the lifter's pressurized oil feed in range to receive oil. As I am sure you are running a pretty big lobe on the cam. Great looking build its identical to mine, minus the rods.
#35
Former Vendor
