What size pulley for A&A V3 Ti trim E85 LS3
I need some help/advice in choosing a smaller pulley. The car is a 2008. Mods are: A&A V3 Ti Trim, headers, cat back, E85, small cam (228/232). I have the 4.0 pulley on there now.
I made 750whp with a 3.4 on my V-3 Ti on a Mustang Dyno with my 07Z. It also had a mild cam, headers, and meth. After the belt stretched, I got some belt slip so you may have to adjust the tensioner after a while. I decided to go secondary drive with 8 rib instead and picked up 2 pounds of boost.
Correct but I was curious if he had the ability to run e85 and 91 via a flex fuel kit. I want to run e85 under boost but I use my car for road trips and e85 can get hard to find.
I use to run a 8"/3.125" combo on mine.
You can overspin it, but I would not do it on a V3 self-contained head unit that does have the HD gears. A stock balancer and 3.4 will put you near the stated max rpm limits of the V3.
3.4 and let it eat.
Mine was an V3 T-trim and its still going on my buddies car with the same combo. I ran the shi*t out of it too.
