After alky, where did you mount w/w tank?
Hey All just wondering if anyone could suggest be the brand and where are you mounted your windshield washer universal kit or some other option
After using the oem washer tank for alky id like to simply see what others have done. Z06 btw with eforce. I didnt find much in search
speedz06 (07-15-2017)
Received 1,193 Likes
St. Jude Donor '15
I just left the washers connected to the tank with meth in it. Dries a little too fast but I rarely need it. Works fine when I do.
I was just asking Alkycontrol the same question because I don't want to loose my WW tank. I use mine quite a bit on trips. They recommended adding a washer bottle on the C6 and mount it passenger front. I pan to take a look when I get back in town and see if I can find a good place to mount a washer bottle.
i dont but i can when i get car back together. look in your sig, area to the left of intake tube, drilled a hole in that plate and used alum plate to make a bracket. its a snug fit but looks sorta OEM
yes..a pic would be great. I can figure it out but I would hate to set it up, then see what someone else did and be like..oh man why didnt I think of that? I'm hoping to get a dry sump car pic.
Just run 50/50 water/meth, which is basically washer fluid. Hell you can use washer fluid for the meth kit.
There really are times when we need our windshield washer though. Especially going through jersey
No way I would have a fuel inside the cabin with me. Huge safety hazard. Just use meth on your windshield, and be done. No added cost, no safety issues.
its a proper fuel cell with a proper fuel cap with stainless lines that are outside the cabin compartment.to each there own.have seen 2 cars burn to the ground at COTA with windshield washer reservoir and plastic lines
