C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Scale sheet or hptuner file for my new map(ls7 intake:12623671) ???
Old 07-25-2017, 08:24 AM
always faster
always faster's Avatar
Default Scale sheet or hptuner file for my new map(ls7 intake:12623671) ???
After some research in the archive i ve just ordered my new map sensor to go on my ls7 intake(2008)
Gm part number: 12623671
Can someone send me the new scale sheet that i should use or a hptuner file for the new map ???
I got no experience in Hptuner so please be nice
Old 07-25-2017, 04:38 PM
Tech
Tech's Avatar
I'm not using that MAP, so I can't send you any data. If you can find a vehicle that used it, you can go to HP Tuner's tune repository and find the settings from a factory calibration.
A quick google search shows people having problems with that sensor. Hopefully you've done your due diligence.
Old 07-26-2017, 04:44 AM
always faster
Well i could easily return it
What is your suggestion for a good map(need one that clip to an 08 ls7 intake) for a boost engine.
Old 07-26-2017, 08:23 AM
schpenxel
schpenxel's Avatar
Received 1,194 Likes on 1,053 Posts
St. Jude Donor '15
Is that the 3.3 bar sensor?
A 2 bar cobalt sensor works as well
Old 07-26-2017, 10:46 AM
Tech
Tech's Avatar
How much boost? Do you actually need 3 bar? I suspect you'll lose resolution if you use a MAP too big for on your intended use. As Carson mentioned, the 2 bar Cobalt sensor is popular if you're staying under ~14 psi.
Old 07-26-2017, 11:01 PM
always faster
Ysi @ 2.85" with 8" balancer so i should be over 14 psi...
So what should be the best recommandation.
Old 07-27-2017, 11:48 AM
Milan
Milan's Avatar
Use the ZR1 map sensor
Old 07-27-2017, 04:45 PM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Can, but have to change connector and drill out the hole on the manifold, LS7 MAP sensor is LS2 style basically
Old 07-27-2017, 11:01 PM
always faster
So if i want to avoid switching connectors is there any other option for me ???
Old 07-27-2017, 11:04 PM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Dsx makes a 2.5 bar sensor or that 3.3 you have should fit. I’ve never used one though. Google the part number and linear offset and you should find the values you need for the tune
Old 07-28-2017, 12:50 AM
Milan
Milan's Avatar
You can get an adapter harness and the hole takes like 1 minute to drill out.
Old 07-28-2017, 04:52 AM
always faster
Drilling is not a problem , what size do i need to drill ???
Ok so:
-Ls9 map sensor: 12592525
-This harness:
http://www.lingenfelter.com/product/...l#.WXr65oTytyw
-And i use the stock zr1 value for the map scale.
Is everything ok ???
Setup: Ls2 darton sleeve 427ci /ETP Ls7 heads and ysi going in a 2001 C5Z
Old 07-28-2017, 09:08 AM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
I think everyone assumed this was going in a C6 Z06 since you never really stated otherwise
What vehicle and what ECM are you actually using this with?
Old 07-28-2017, 10:19 AM
always faster
2001 C5Z stock ECM.
Old 07-29-2017, 01:15 AM
always faster
2001 C5Z stock ECM.
So does it change something or am i good with the zr1 setup ???
Old 07-29-2017, 01:46 AM
Milan
Milan's Avatar
Doesn't change anything. I run it on my 02Z
Old 07-29-2017, 01:56 AM
always faster
Cool will order the map and the harness
Did you just use the zr1 map data and it was fine ?
Old 07-29-2017, 06:51 PM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Of course.
To Scale sheet or hptuner file for my new map(ls7 intake:12623671) ???
Quick Reply: Scale sheet or hptuner file for my new map(ls7 intake:12623671) ???
