LSx Boost Happy intake manifolds
#242
Former Vendor
Finally something purely for the Tall Deck LS7
Specs
LS7 Tall Deck bottom end, Holley Hi Ram Flange'd to use their cast top end. Spec to engine revving to 8500-9000rpm (5.6" runner length 15% taper between csa of port and csa of vstack entrance
Custom Dual TB 102mm Plenum top, fully welded inside and out.
Will be running on a twin turbo 60lbs boost setup billet block lsx, 3000 WHP Meth car. No I will not release the owners name, they can release the info if they choose.
Top plenum is full 1/4" sheet will be welded inside and out being easily 100psi boost safe. Can be setup no2 burst plates etc.
Bottom plenum being very triangulate in design will remain 3/16" sheet material being fully welded inside and out.
Specs
#243
Former Vendor
note*
velocity stack spacers can be added to lengthen runners for lower revving engines.
Top plenum piece sells separately for anyone with a current holley hi ram that would like to upgrade.
Dual 90 or dual 102mm tb
#245
Former Vendor
Haven't posted in a moment, I'm horrible at keeping up with forums when all I'm doing is designing and burning welds out all day hahah.
Got some ultimate new things coming out.
"mod ram" manifold
uses a shorty style sheet metal modular design "holley hi ram plenum flanged" plenum bottom. The ports inside or drilled and tapped to accept interchangable runners to tune your setup 100% perfect. You can pull your plenum top, change runner lengths all on the dyno.
this means you can use a holley top, or buy one of mine. This also means if you happen to already have a air water core from someone else you can drop the overall height of your build and have a tunable runner. virtually unlimited options here.
coming to cath, ls3, ls7 standard and tall deck. LTx as well.
"mod ram" manifold
yur2slo (03-27-2018)
#247
The horizontal upwards facing trumpets make the most sense really, as they can add more length, leave the end of the trumpet unshrouded and still keep a somewhat low profile.
Surprised more dont offer them like that
Having an interchangeable trumpet option is also good...but it does seem from almost every intake test out there that some sort of medium length offers best all round.
#248
I saw the beast you sent me in email... I love the idea of the modular approach. How does the trumpeted (longer) style runner compare in length to FAST's short/med/long or the MSD runners?
#250
Former Vendor
Beautiful new LTx Vette Intakes look perfect in every way!
New thick billet head flanges have inj bungs cnc machined in (but not fully drilled through) already. They are pilot drill started so all the customer need do is drill 5mm through pilot first then 8mm. Inj bung is fully seat cut and ready to go. Also fuel line bridge has been incorporated now so now more routing the fuel line over the flange, direct bolt down assembly!
$1750 shipped bare
$200 powder or polish options
$200 fuel rails
$1750 shipped bare
$200 fuel rails
