C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
A&A V3 Procharger
Old 09-09-2017, 08:36 PM
Akatsuki_c6
Akatsuki_c6's Avatar
Default A&A V3 Procharger
Hey my name is Sonny and I have a 2008 C6 with an A&A kit on it. The car recently started to overheat since I am running the OEM radiator. The fans would turn off around 200-205 degrees. Another member mentioned that there might be a secondary fan switch that I am unaware of where to look for in the car. I am thinking if I should just purchase the D3 ProSpeed Dual Spal Fan Shroud with PWM Speed Control but it does cost $900 and want some opinions if this is a solution for my overheating problem. The coolant temps drop when im driving over 50mph just an FYI. Let me know thanks much appreciated.
Old 09-09-2017, 11:25 PM
Z06Qazi
Z06Qazi's Avatar
D3 dual fans would do the trick... had the same issue - with the D3 i havent seen over 195* Yet.
Old 09-09-2017, 11:37 PM
Akatsuki_c6
Thanks for that information much appreciated 👍 D3 it is then!
To A&A V3 Procharger
Quick Reply: A&A V3 Procharger
