Rim removal for cleaning
Buy a gallon jug of meguairs wheel brightner and mix 10:1 for easy cleaning. It'll last you a long time even with weekly washes. A wheel brush will help as well.
http://www.autogeek.net/meguiar-s-wheel-brightener.html
It will also make cleaning the brake dust off the wheel wells, calipers, and suspension a cake walk. You can mix it stronger for stubborn grime and brake dust. The 10:1 is great for cleaning road grime off your engine block and stuff as well.
dont forget to tighten in a star pattern in 3 levels of tightness to avoid rotor damage
1 - Install lugs by hand
2 - Snug with wrench
3 - Torque
Each time go around the wheel in the below pattern.
Drive the car and re torque again
3 - Torque
