C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
YSI-B vs F1-X
Old 09-13-2017, 07:55 PM
Blue by U
Blue by U's Avatar
Default YSI-B vs F1-X
What are all the differences? I've read a lot and seems like 50 cfm difference, advantage to f1x. Ysi b is 1950 cfm f1x is 2000 cfm. Everything I've seen, seems like f1x cars make a good amount more hp. What is everyone opinion? Anyone ran both?
Old 09-13-2017, 07:57 PM
Blue by U
Blue by U's Avatar
Old 09-13-2017, 07:58 PM
Blue by U
Blue by U's Avatar
Old 09-13-2017, 11:08 PM
Detoxx03
Detoxx03's Avatar
What's your goals?
Old 09-14-2017, 07:27 AM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Both are decent and depends on goals application. For 1150 or less I would just do the Ysi (even non-billet) and call it a day. ECS or A&A bracket, nice 10 rib kit, and enjoy. Or the F1A-94.
If you want to make 1200-1500rwhp, then do the F1X. From what I've seen, the F1X isn't as reliable, especially for a street setup as the long time proven Ysis, so unless you need that extra flow, or it is just a race car, go with the Ysi or even the F1A. If you need that extra 200-300hp then do F1X.
Old 09-14-2017, 10:48 AM
algZO6
algZO6's Avatar
Im running a 365 with a modded ysi-b and my buddy has a 416 with a f1-x. Both are autos and will be running at Street Car Takeover in Phoenix next month. It's not exactly apples to apples but results should be interesting. I will post up results.
Old 09-14-2017, 11:23 AM
lt1z
lt1z's Avatar
The F1-X has more top end potential but it depends if you are actually going to spin it hard enough. The YSi may be a better choice in the 1100whp range. The YSi does really well on the smaller cube engines but I'd go F1X on 427+ ci
Old 09-14-2017, 12:45 PM
croatbob
croatbob's Avatar
Street car id go ysi. Race car or dyno queen I'd go f1x
Old 09-14-2017, 01:05 PM
Blue by U
Blue by U's Avatar
Thanks guys. Just curious on everyone opinion. I currently have ysi-b with 2.75 pulley and an ATI 10% o.d . Balancer, new style A&A brackets, 427, 10 rib. I have a boost leak somewhere, it's only making around 18 lbs but was making 20lbs. It made 915 rwhp through air filter and no meth. Next pull was with no air filter and meth, but my mantic twin disc started slipping at 5,000 rpm so no number and need new clutch.
Old 09-14-2017, 01:06 PM
Blue by U
Blue by U's Avatar
What problems have people had with f1-x?
Old 09-14-2017, 03:16 PM
bdickey058
bdickey058's Avatar
How does the f1a-94 do on larger cubes such as a 427. my d1sc falls on its face at 6000 rpm. ive made 820 wheel hp but i dont believe its making anywhere near that now as my trap speeds are 132. car does have iron lsx and full audio system. and 4 24 lbs batteries in the rear bumper. shes about 3800 lbs.
Old 09-14-2017, 04:20 PM
Unreal
Unreal's Avatar
Blowers coming apart, bearings dying, etc.
TTBlueZ06 (09-18-2017)
Old 09-14-2017, 04:28 PM
bdickey058
bdickey058's Avatar
[QUOTE=Unreal;1595570160]Blowers coming apart, bearings dying, etc.[/QUot
Was that directed at me?
Old 09-14-2017, 04:55 PM
Detoxx03
Detoxx03's Avatar
Pretty sure he was answering the F1X problem question
Old 09-14-2017, 05:54 PM
Unreal
Unreal's Avatar
Yep.
Ysis come apart too, but it seems more rarely. Niether are perfect, but unless I was going for 1300+rwhp in a vette, I would stick with a Ti/D1X/Ysi
Old 09-16-2017, 01:57 AM
c5mtl
c5mtl's Avatar
I've had both in the same car....ysi pulled strong but I feel it ran out of steam near the impeller redline ...it took a 3650lbs car to 8.8@157mph so I can't complain ...I don't have a time slip with the f1x but I can tell you at max impeller speed it's pulling much harder than the ysi and from what I hear the faster you spin it the happier it gets until it eats it self up!
Old 09-16-2017, 12:38 PM
ripjr123
ripjr123's Avatar
curious on the setup myself i also have a 416 and auto and in the process of installing a f1x what heads are you guys running and what kind of power did the set up put down and what fuel?
To YSI-B vs F1-X
Old 09-17-2017, 06:20 PM
algZO6
algZO6's Avatar
it has tfs 255 heads. it ran an 8.5@156 and put down 1200 at the wheel. we here having some belt issues so we had to call it quits. definitely more in it.
ripjr123 (09-21-2017)
Old 09-18-2017, 10:45 AM
TTBlueZ06
TTBlueZ06's Avatar
YSI for a 1100hp or less street car.
F1X for a race car.
F1X will make way more peak power but does not have the mid range that the YSI has.
YSI tends to be more reliable being oil fed, you will find far less stories of blown up YSI units vs blown up F1X's all over the place.
LSTX (07-22-2023)
Old 09-18-2017, 10:52 AM
ysb02
ysb02's Avatar
I think the f1xs have more issues because everyone spins them way beyond ati's suggested limit. If you don't over spin them they really don't make much more than the ysi
Quick Reply: YSI-B vs F1-X
