On3 Turbo Build
#361
Having to use 4 waste gates sucks. But I don't see how eliminating 2 with a equal size "brand name" waste gate will make it manage boost control any better, or the same.
My Chinese waste gates work perfect on my Mustang.
Either way, I hope it works for you!
#362
Iv heard that their wastegates do not control boost very well, which im not sure why or what makes them different from any other(im sure design). Were going to try the stock configuration and if that works ok im going to run with it for the rest of the year.
#363
My build has had some progress but it's been very slow going due to recently adding a new baby to the household and crazy work hours. I've still yet to see if I'll need to run a scavenge pump like you did or not. I did have to buy new fittings to try to run the drains differently in hopes that I can prevent that but we will see. If it werent for all the changes ive made to make things work better or look better, I'd probably be done by now. Not necessarily in a hurry but this has taken at least twice as long as I had intended at this point and I'm still not 100%.
I know On3 made the kit around an LS7 so they had to keep the boost levels a bit lower due to higher compression. I'm wondering if trying to run say 10-12 lbs vs. their 5 or 6 would be a little easier on the 2 wastegate option. Ive given this a lot of thought since it would really simplify things on the setup. Either way, very curious to see your results and also looking forward to you actually having the car on the ground and running, I know its been a journey for you.
#364
Im thinking it will be around 12-14lbs, I hope just two gates work. Depending on how this kit works the rest of the summer, this winter I would like to upgrade to a paid of Garrett GT3582's. I think I can fab up drain lines so I wont have to use a scavenger pump. On3 turbos are junk and leak no matter what, they said a 3582 will fit in the housing made for this kit. So with a decent turbo in there I think you could get away with no scavenger pump. Id also like to route the dump tubes for the gates into the down pipe, it looks like it would be super easy since they dump right next to the down pipes.
#365
#366
Going to be a long couple weeks waiting for my car to get back, any guesses on what it will make? Im guessing 720 at the wheels on a mustang dyno.
#367
My single cast wheel On3 88mm dyno'd well and continues to work flawlessly. eboost2 controlled 6-13lbs with 2 ebay 46mm wastegates. I'm pulling the 7lb springs out this weekend to install 9lb springs and see what 18lbs looks like.
What fuel are you running? I'm 11:1 compression on a stock bottom end and couldn't push past 9lbs on 93 octane without drastically dropping timing. e85 and 21* gave me 851hp with tire spin @ 13lbs.
#368
#369
http://www.airpowersystems.com/corvette/apscc6-fss09/fuel_system.htm
this unit came with the used cxracing kit I bought from a forum member. not sure of the size of each pump, but it had plenty left in it @ 13lbs. 1050x injectors were at 66% on that run as well. Little room to grow before upgrading them.
#370
It will be interesting to see what happens, I bought 1200CC injectors but I still think my pump is going to be too small for my 800rwhp goal.
#372
It has to be getting close to being done as it's been close to a couple of weeks. Any updates?
#373
I haven't heard anything yet. Its been 3 weeks now, my garage is getting lonely. He said he was about 3-4 weeks out when I dropped it off so hopefully it is back soon.
#374
No real updates on the car, stopped by Wednesday and they had the fuel system done. Suppose to get the car back in a couple days. But I did pick up a set of new welds
#375
Received 2,796 Likes
2021 C6 of the Year Finalist - Modified
Those are bad ***.......is your tuner the same as did your Papa's car....? just wondering.........
#376
Really interested in seeing some numbers. I know you'll make more than me with a bigger motor and cam, but at least ill have an idea. When I talked to On3 they said they had an LS7 car making 890whp and he felt that was about max effort on this setup. Not sure of all the details on that setup or if it was straight pump gas or not, but I'm curious to see where youre at.
#378
Well more and more bad news. Car was on the dyno last night, tuner was adjusting stuff which required to start and stop the car a few times. About the 3-4 time the starter went up in smoke. Pulled the car off and fixed the starter. Put the car back on the dyno today and could not get it to idle correctly, cylinder two was noticeably colder. Did a compression check and showed about 25psi. Going to do a leak down test and hope for the best.
#379
Pro Mechanic
Received 3,938 Likes
sure seems like if you didn't have bad luck, you wouldn't have any......................
here's hoping it isn't anything "too drastic" and you can at least get it out and running soon..................
keep the updates coming G............................
may be time to borrow one of them BS GS's out there in NE????????? H1 has a new to him toy, may not miss his if he is running around in the Draggin' Wagon..............
#380
Received 1,193 Likes
St. Jude Donor '15
Might be time to throw in a truck iron block with some opened up ring gaps and turn it up
