Heading to the wind tunnel
We have an appointment on the 23rd at the A2 Wind Tunnel in Morresville, NC. This will be our first time down there. I am hoping to ensure the car has a good f/r balance and then focus on reducing drag during the tests.
I have 2 hoods, my homemade cowl as well as a new VFN Sunoco cowl. I may try to locate a cheap stock hood to get a baseline number as well.
Will also be testing changes to the spoiler, splitter, side skirts, hood vents, wheel covers, mirrors, cowl, grille opening, fenders, etc.
Data should be helpful on our quest for more mph, as well as ensuring a level of safety.
Should be an experience.. I have no aero background, but I did read a book
My hood:
vs. VFN
My hood:
vs. VFN
every time I have my c6 up on the lift I get upset looking at the rear bumper design from underneath... it looks like it has to catch a ton of air at high speeds and mess with the rear stability some... I've thought about building my own front splitter extended to middle of engine bay possibly and a custom rear diffuser that would extend to middle of rear suspension cradle... I worry more about airflow under my car then over I guess...
if you can; set up a go-pro under car pointed to rear and see how much wind tunnel smoke gets hung up by rear bumper ???
SO COOL. really interested to see what data comes out of this.
that's a good idea on putting gopro on a big stick so can look under neath
I remember LMR did this with their blue tejon car, maybe worth calling them to ask them what they found
I'm going to guess your vented hood has lower drag
No idea on your class rules but I toyed with the idea of building something out of a thick sheet of carbon fiber with studs around the outside edge that fit over the front bumper hole and into holes drilled around the opening to just cover the whole thing when at the track. Then I remembered I drive a street car (haha). But might be worth testing to see if covering that whole thing helps. I would think that in a run that long given heat generated etc that the airflow through radiator, etc doesn't really matter over the course of a run.
I do have gopro's in the car, but hadn't planned on putting them under the car.. Great idea! Just ordered a couple different clamp mounts, thanks!
I will be fabbing up 3 separate pieces to block the front end as well as lower the splitter closer to the ground. We have already blocked a large chunk of the radiator with the intercooler, so blocking part of the grill should not be a deal breaker.
Very interested in the results. Had a front and rear splitter fabbed on my old C6Z as well as flat panels underneath to smooth everything out. Never had the chance to run it full-tilt with that set up. Was always curious what adding the GTC-500 wing to the Carlyle drag wing would do (the idea of adding a little downforce for traction instead of having traction control pull power) Awesome that you are doing this.
really awesome.
if you google "LMR corvette tejano blue" you can see what they did to the rear bumper of their vette where they added some vents, kind of like how the honda drag guys to their rear bumpers. I know LMR went to wind tunnel with that car so maybe they were onto something.
Take plenty of tape and board to fab stuff up! You might needs guides up front to guide air to the rad. You can then make the front opening smaller. Venting the hood would also help. Plenty of gains to be had at the rear end just cleaning the airflow up.
Please let us know the results!
Some cameras to record the results would be great too if smoke etc is being used.
But if you can prevent most of the air getting under the car in the first place that probably negates some or most of the effects of any air towards the rear valance area ?
And anything that can reduce overall lift can only help stability, although I'd imagine those cars already being extremely aerodynamic and well designed should be very stable at speed anyway ?
Looking forward to the results and what you find !!! I run 1/2 mile events at this time but hoping to get to Mohave Magnum 1 and 1.5 mile events later next year.
Received 1,194 Likes
St. Jude Donor '15
Sub'd
Are you having any issues with traction? I'm not sure if it's in your scope for this trip, but it would be interesting to see what types of changes to the rear wing might add rear down-force without creating too much drag.
The goal is to end up with minimal down force front and rear (as close to equal as we can get) and then reduce drag.
Just about ready to go.. All the pieces are just temporary for testing. I have quite a few other pieces mocked up to try as well.
I will spend Saturday packing and cleaning off the 250mph bug guts
schpenxel (10-20-2017)
Looking forward to the testing !!!
I''m also going to do the flat under panel on the ZR1 splitter, back to the engine cradle like you are testing. That should help quite a bit with airflow under that area of the car
