Tf215 heads on a blower car?
Came across a good deal on a set of TF215 heads.....to small for an Ls2 with centri Ti trim blower?
Why would the heads be too small? I'm not really sure what you're asking. Blower doesn't care what size the intake port is. It does care about the efficiency of the port, but to a lesser extent than an NA engine.
I know most people go with the TF225"s when upgrading....wasn't sure how these would compare as far as flow rates?
225 is a better choice for the 4" bore.
i run the 220 as cast and have had great results. this is on a stock bore ls2.
