Fuel system on a budget......lil I know!
Driveline is out for clutch install....no better time to do a fuel system upgrade. Going to pulley down to a 3.4" pulley on my ti-trim/meth/93 Ls2. Wanting to put 2 walbro 450's intank....who makes a good double hanger setup?
as far as budget goes, adding a pump on a hoobs switch or rpm switch is the most budget friendly, leave the stock pump alone and tap the back of the tank like A&A and connect back to the factory line like ECS and you are good to go. There is a local guy that has an a1000 setup like that with his 2200R and I have had good luck with the AEM 380 on two cars.
DOUG @ ECS (12-04-2017)
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,085 Likes
Fore is the only one I know of, I tried doing a drop in 450 and had nothing but issues with fuel transfer between the two tanks (even with the lingenfelter plugs) and fuel pressure (not sure what was going on) I ended up doing on magnafuel 750 that draws from both tanks.
If I can make a suggestion, if you do not want to buy our entire fuel system, which really is priced very well IMHO and is all pre-made ready to go without having to drop the tanks, at least buy our fuel block for the gas tank.
Just tapping the tank is NOT the correct way to get you fuel supply, I have never seen one in here yet that didn't weep around the fitting.
As they say, "there's a right way to it, and a wrong way".
Thank you for the referral.
Received 1,194 Likes
St. Jude Donor '15
I must have the only drilled tank w/fittings that doesn't leak. So far so good on mine
I agree the ECS block is the better way to go though, if it had been a bit less money I would have used one for sure
St. Jude Donor '15
Yeah that’s what I did too. Was really careful not to make the hole too big and only tapped it barely enough to get a fitting started and let the fitting cut the rest. Then used clamps to keep the lines from moving around.
It works but ECS block is still preferable IMO
Fore hanger or the ECS block. Wouldn't do anything else. I stuck two 450s in the tank with a fore hanger myself. Dropping the tanks with the driveline in isn't bad at all, but since you have it out there are no excuses
If you do go the dual 450s route keep in mind you'll need to prime your car before starting it if it's been sitting for a little while unless you install a checkvalve in the feed line.
St. Jude Donor '15
Can also turn the prime time up in the tune, I think stock is 2 seconds, I switched mine to 5 I think. It only seems to really apply if you hit start button w/o clutch being pushed down but I've just gotten in the habit of doing that if it's been sitting for a few days.
My car fires up instantly. Even sitting for a month. Zero issues with priming.
