My Boostrd 427 Build
I have seen cars make 1000 on grand sport ls3 cranks because they are forged and dry sump. But that is pretty much pushing them to limit. I don't know much about ls7 cranks.
If you haven't already, look through this thread. This is where I bought my engine.
https://www.corvetteforum.com/forums...lock-sale.html
im wanting to go eagle crank and rods and diamond pistons should be good for 1000hp
Why an Eagle crank and rods?
427V8BB (02-12-2018)
What year/model transmission and diff are you running? That is going to be the Achilles heal to making reliable power.
Molnar makes nice parts also and I've spoken to him. He said under 1500hp his parts will be fine.
Remember that if you are using the LSA piston squirters they most likely won't clear a 4" stroke unless you use Katech or similar aftermarket ones.
just what khole recommended me to use. I want a barrier of 1200whp then down the road years I’ll redo my rotating assembly for 2000hp and maybe drop every pretty penny to make this a 2000whp car. All thoughts but for now I want a 1200whp capable rotating assembly is eagle crank and rods enough?? Also doing NOS later like in 8-10 months
2008 c6 z06 tr6060
gotta see if they have pistons squirters it’s from weapon x Motorsports
getting a clutch to handle the power what ever else breaks drivetrain wise I’ll fix when it does
Received 1,194 Likes
St. Jude Donor '15
Is ERL in business? Thought they closed down for the performance market.
Steve at RED has a similar sleeping solution though if needed.
afer pricing yhe ls9 setup I got to wait cost more than i thought it would and I can’t get rid of my heads so guess I’m staying with them. Would it be safe for 10:1 compression on this 427 with a blower cam and a stock ls7 intake and TB and drive around on that low of compression for 91 until I get money for a blower wanting atleast 800whp on the blower for 91 and meth. Would this be fine? Is the compression good for 800whp on 91?
yeah im a bit confused on it also, since it’s getting a new bottom end they need to install and balance it do they have to rehone it? And what’s the cost? Thanks guys
#35
still haven’t figured what builder to go with khole said he would be he’s kinda far I’ll see and contact red or concord engines he’s some guy who use to race in the nhra.
#36
Hilarious reading this with the OP blocked. Had to get a new name because of how bad he was on his original one, as soon as he said who it was, blocked him, and noticed the behavior hasn't changed.
If a basic heads/cam setup couldn't stay together for a few months, no idea how he plans to keep a 900+hp build together.
#38
LSA on a C6, it wont make 1000 but the car is fast with nitrous, we just did a 408 with a better cam and bigger crank pulley. Going to bump the nitrous to 150
https://www.corvetteforum.com/forums...ll-update.html
427V8BB (02-13-2018)
#39
#40
Make your own call on that one. Post style is shockingly similar, as is the location, and way he is acting.
