d3pe fan s/c install help
z06 radiator just installed d3pe fans. Already have spacers in radiator support. The YSI is so close to fans i cant even get boot in. The bolt to fan is hitting the A&A charge pipe. I think by loosening the radiator support i can get boot/clamp in and then tighten back up but i dont think this will work anymore. Need advise on setups... was thinking buying a 6" hose and a 90 and let it smoosh against radiator whatever needs...?
Originally Posted by gameover4
yea hose doesnt go there just held out way for pic. Do you have link on process of modifying rad support?
Actually forgot I had them here if this works. If not I'll repost later.
https://i.imgur.com/8l2ijCV.jpg
https://i.imgur.com/uaEG7Ce.jpg
https://i.imgur.com/jAXWyBE.jpg
https://i.imgur.com/hyNEzUt.jpg
i will try this. did you have to pull front bumper off? how much did you gain from dropping it?
I did this mod to my support and I still have to run spacers for the A&A kit but not nearly as big as what the kit came with. I'm working on it currently. Looks like I can run the small ones in back and then just a few washers in front and it'll clear. I have Dewitt's rad and fans
Which reminds me I have a job in Baton Rogue coming up. I'll have to bug you on things to do.
