Will NT01's hook?
Will NT01's hook?
Since the r888's are a 3 month wait right now i'm looking at Nittos NT01's because they come in stock sizes 285/35/19 and 245/40/18. Will these tires hook from a 30 or 40 mph roll?
600hp base c6
600hp base c6
i ordered some and they will be here tomorrow.. as soon as they get mounted I will let you know
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07
I have a set on my twin turbo C5 Z06...im in the 550rwhp range and they hook 2nd gear up great as long as its not too cold out.
I have use the NTO1 with coil overs and prep suspension and thought they hooked great on the street with a almost 700 rear wheel car on a 30mph roll.
Tops is the Mickey Thompson drag radial R just amazing even from zero nether is to be trusted on wet.
Cant say enough about the NT01. ran about 32 psi in the rears and making 774whp on nitrous to the tire and these things hooked in second. Off nitrous I make 555 and have no issues hooking in the dry from 1st and even under damp conditions it hooks in second. fantastic tire and are not noisy like r888. absolutely love them
