RWHP guess after winter mods
Cruising
Its finally spring in IL and I just finished up some winter mods. I was wondering what kind of power might I make?
C6 base A6 car
APS TT
fast 102
BTR TT stage 1 222/231 .602"/.598" 112+4
ECS stage 1 fuel system
Flex fuel sensor
120# injectors
Full 3" exhaust no cats
I going to try to run 10#s of boost
Before winter it just had the APS kit. I will be getting the car tuned and dynoed soon. Thanks!
C6 base A6 car
APS TT
fast 102
Flex fuel sensor
120# injectors
C6 base A6 car
APS TT
fast 102
Flex fuel sensor
120# injectors
C6 base A6 car
APS TT
fast 102
Flex fuel sensor
120# injectors
Cruising
Injectors are 80s I believe,stock pump with boost a pump. Getting tuned on 93.The heads are stock. The car is getting tuned and dynoed next Wednesday.
I haven’t had time to put the ECS fuel system in or the flex fuel sensor. So I’m just going to get it tuned as is.
Cruising
Good numbers, the car has a lot more potential if you wanted. I have an ls3 with btr stage 2 tt cam, twin 62mm turbos, should be good for 800-1000. switch to E85 and you'd see a huge improvement just in that(80ish hp)
Cruising
Nice set up. How many pounds of boost are you running? I will be running E85 at some point too.
