C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
1k+HP Drag setups
Old 05-02-2018, 09:40 AM
gameover4
gameover4's Avatar
Default 1k+HP Drag setups
After researching ive seen a million different setups. What size wheels and tires is everyone running for 1k+hp setups? im look at some welds and possibly hooisers/mt/m&H. it will be for strip/street racing. mainly hits on our local mexico street. im currently running 345/30 nt05r as a daily tire
Old 05-02-2018, 12:43 PM
JetstreamGS
JetstreamGS's Avatar
At that level you're going to need spindles and 15's.
Old 05-02-2018, 01:50 PM
kromberg
kromberg's Avatar
28x12.5x15 Quick Time PRO.
It is not a question of power level, but the amount of power being put down off the line. If you launch at high RPMs with heavily modified suspension, then you want a bigger sidewall to help absorb the initial hit off the line. Even with high RWHP, if you leave at lowish RPMs and have being much stock suspension a 17" drag radial is fine.
Old 05-02-2018, 02:40 PM
1SwtRide
1SwtRide's Avatar
Old 05-02-2018, 02:57 PM
BoosTTed C6
BoosTTed C6's Avatar
3rd vote for spindles and 15s.
It will hook 1000+ hpr. Ask me how I know.....................
Old 05-02-2018, 03:29 PM
gameover4
gameover4's Avatar
im looking at keeping the stock suspension and brakes (still majority street car) so im going to go with weld 17 or 18s. was wondering how wide rim and what size is hooking best.
Old 05-02-2018, 04:55 PM
WestCyril
WestCyril's Avatar
Depending on condition of what you're racing on a 17 inch slick/radial should be ok. 17x10 with a 305/45 Et street R or Biasply slick is the most commonly used 17inch tire I've seen.
Radials will be harder to make hook on the street or no prep surface. A slick is easier to make hook and typically more consistent.
If you're primarily roll racing the car from highway speeds a 17 inch radial will be fine. Dig racing will be a little harder.
Like others said I would recommend a 15 inch wheel and spindle kit. Carlyle kit allows you to use e brake etc.
Old 05-02-2018, 10:35 PM
95vettski
95vettski's Avatar
What power adder and transmission?
Old 05-03-2018, 08:04 AM
gameover4
gameover4's Avatar
lsx ysi combo and running factory Z 6060 6 speed with 3.90 rpm rearend
Old 05-03-2018, 08:34 AM
gameover4
gameover4's Avatar
looking at the weld rts s71 17x11 and M&H 325/45/17.
Anyone had issues with the 28" tire fitting?
Old 05-03-2018, 08:44 AM
realcanuk
realcanuk's Avatar
St. Jude Donor '13
Running same. They fit fine. Rub a little on "dips" in the road if you don't raise the rear a little.
Old 05-04-2018, 01:26 PM
95vettski
95vettski's Avatar
Looks like the best choice for a 17" wheel. Although, that 3.90 gear won't be helping.
Old 05-07-2018, 08:21 PM
ZincGT
ZincGT's Avatar
17x11 with 305/45/17 Et Street R
Old 05-08-2018, 07:03 PM
xBoostx
xBoostx's Avatar
I too have the M/T drag radial R 305 45 17 with a 11.5 inch wide rim and works but a 10.5 would be better width rim for that tire.
I should say these tires are superior by far compared to nto5r and even Hoosier drag radial R
if you could grab a hold of knurled beads rims highly suggested.
Old 05-08-2018, 08:22 PM
ysb02
ysb02's Avatar
Is it worth it to get the 17” wheel 28” tire wheels with locks or not needed?
Old 05-27-2018, 09:57 AM
jayyyw
jayyyw's Avatar
Must be a wild ride with those 3.90s
Old 05-27-2018, 11:38 AM
Ant-Man
Ant-Man's Avatar
Get some 16s and c5 rear brakes.
Old 05-29-2018, 09:32 AM
gameover4
gameover4's Avatar
i ended up buying some weld s71 in 17" and some M&Hs
To 1k+HP Drag setups
Quick Reply: 1k+HP Drag setups
