More fuel system woes... help
Platinum Supporting Vendor
Originally Posted by Josh@AandASuperchargers
I always put cap on it, because every time the hood goes up someone walks over and says hey you're missing a hose right there.
The following 2 users liked this post by realcanuk:
Josh@AandASuperchargers (05-15-2018),
schpenxel (05-15-2018)
Thanks all.
Jacked the fuel pressure back up and it all seems to be fine...... after replacing the fuel pump the first time and the siphon pump the second time.
Pretty sure this “corvette shop” was ignorant of the system.
Problem now is I have a service fuel system warning and a CEL. Also fuel gauage is pegged past empty.
Any thoughts. Would love to be able to fix this without having to return the car to this shop. I sure hope the fix does not require the tank to be dropped again.
Thanks all.
I haven’t returned to this shop. I’ve been busy out of town and the car has been parked until today. Drove the car about 70 miles this morning, so now a total of 150miles since I filled the tank. When I returned home, I put the car on my ramp and checked the temp of the fuel tanks with a laser temp reader. Both tanks read about the same thing; at the bottom they were at approx 90* and half way up the sides the temp rose to 111*.this made me think that both tanks had about the same amount of fuel and all was well, except the gauge?
Just reset the CE light. If it detects that siphon isn't working then it goes to zero and gives a CE light. Now that it works it may need nothing more than reset.
Josh@AandASuperchargers (05-21-2018)
Yes clear the codes one more time and see if it comes back now that it should be fixed.
Josh
Took your advice and erased the codes and the fuel gauge has returned to life.
Thanks for everyone’s input and especially your expertise.
I’m doin’ my happy dance
The following 2 users liked this post by EuroRod:
Josh@AandASuperchargers (05-21-2018),
schpenxel (05-22-2018)
Received 1,194 Likes
St. Jude Donor '15
Yeah. No doubt. Tuner should have known better than to turn the fuel pressure down like that.
#33
Well, ....#$@#@&*!
After clearing the code (2068) and my fuel gauge returning to life, it has happened again. Gauge pegs zero, I get a “Service Fuel System” in the DIC and another 2068 code.
I’m beginning to suspect I may have a stuck float?
Ideas?
Ideas?
#34
Stuck float, float bent, or hanging up, etc. Could be a number of things.
