C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Do I need injectors?
Old May 17, 2018 | 04:50 PM
theandrewo's Avatar
theandrewo
Default Do I need injectors?
'08 LS3 m6. Currently running P1SC1 w/4.63" pulley pushing about 4lbs of boost. Belt was slipping so I may get a little more boost when I replace it. Car is otherwise stock (w/NPP). I'd like to end up with ≥600rwhp (it's at 500rwhp as it sits).
I plan to add:
-4.38" pulley (recommended by Procharger tech - should bump me up to around 7lbs)
-1 7/8" LTH
-3" catless X-pipe
-re-tune
Two questions:
1) Do I need to get injectors? And what rating if so?
2) I'd like to throw on the LTH and xpipe right now purely for the sound, but it will be a couple months before I pulley down and retune. Is this safe to do with boost? Or should I wait and do it all at once?
Old May 18, 2018 | 12:40 AM
C U IN REARVEIW's Avatar
C U IN REARVEIW
I plan to add:
-1 7/8" LTH
-3" catless X-pipe
-re-tune
Two questions:
Tune would need to be adjusted after header install
Old May 18, 2018 | 01:55 PM
g23crawler's Avatar
g23crawler
Dont need injectors for 600, but you would need at least a BAP or meth. Dads car has meth and a P1 making 605hp at the wheels.
To Do I need injectors?
