I wanna run Nitrious in my cam only LS3
Hey guys,i just recently purchased a 09 Vette with a Lunati Cam, headers, Intake and Tune. The car made 480whp on a Dynojet. I wanted to add nitrous and I wanted to see what everyone thought i could run that is pretty safe. I obviously know that nothing is absolutely safe but I was thinking of doing a 125-150 shot, I just would like you guys to tell me if its a good idea or not. I am not too familiar with Nitrous but my best friend is running it in his CTSV so i have been learning a bunch of stuff from him. I wanted to keep the stock fueling for now, Thanks for the help guys
stay between 100-150 jetting
you can make a nitrous kit as simple or as complicated as you want, but for the most part here are a few things that you do NOT want to skimp on
afr gauge w/wideband sensor
bottle heater
correct temperature spark plugs w/correct gap for the shot you are running
purge----(this is matter of opinion) but i have always had one just to be safe
bottle heater
First question that I would be asking is if you could pull fuel off the rail and be ok seeing how it's already supporting 480whp.. Assuming the car has a stock pump. I'm not sure how much can be made off a stock pump. I have a standalone on my car for the nitrous.
98rzvr6 (05-23-2018)
Great question, that was also one of my concerns, the car is on stock Injectors and Pumps so i guess i am wondering about that too. Thanks for the help guys
I started running out of fuel at the 100 shot jetting on a Cam-Bolt on LS3. Stock fuel pump. Swithced to the standalone. It is extremely worth it while using nitrous.
jayyyw (05-27-2018)
98rzvr6, Standalone also gives you advantage to run real good gas (insurance) for the nitrous instead of risking the 93 pump.
98rzvr6 (05-24-2018)
https://www.summitracing.com/parts/n...SABEgJrZvD_BwE
nitrous outlet has a direct fit stand alone kit for the c6.....but follow me here
why wouldnt you install a kit and start at a low shot and see what the afr and fueling looks like from a baseline?
1-you have to buy a nitrous kit anyhow
2-you may have the fuel you need @75-100 shot and be happy
3-possibly save 500 bucks?
i dunno, maybe i went about it wrong when i set mine up?
stock pumps
65lb injectors
pulling fuel from rail
afr around 11.9-12.2 @ 100 shot still having 58-60lbs @ the rail
stock pumps
65lb injectors
stock pumps
65lb injectors
stock pumps
65lb injectors
stock pumps
65lb injectors
stock pumps
65lb injectors
The 67# injectors, those arent stock, right? Where did you get those at? Which brand
Unless you're going with a dry kit, stock injectors are fine for a wet kit. My concern was pulling off the rail with a stock pump if he's already making 480whp. Will an ls3 pump support 580-630 whp?
I have a cam/ heads and header GS. 490 on Ethanol with a mustang. I’ve ran it on bottle for a few months now. 200 shot. If you are going over 125 you should run a stand alone set up. A good set up is safer and cheaper then a failure. You can find a stand alone used usually online. They have built in pump and pressure safety switch. -6an.
I actually have one if you need it.
