C6 Z06 with a Blower Question
Is it necessary to put a shorter Radiator when throwing a supercharger on this car ? I have a full size dewitts with D3 fans and I really want to keep it that way. Is it the blower intake that causes the clearance issue ?
No, in fact it hurts significantly. It is only needed if you want to run a full 4" over the air intake system to make in excess of 1100+rwhp as the stock ECS/A&A dongles that fit full size radiators will make 1000+ with ease.
Z06Qazi (07-08-2018)
Thanks , does the radiator need to be lowered ? I have a A&A kit .
Install instructions clearly show what needs to be done. Yes the radiator is spaced down.
