C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Test Nos mini with car off?
Old 08-29-2018, 03:24 PM
emoFTW
emoFTW's Avatar
Default Test Nos mini with car off?
Is there anyway I can test my nos mini with the car off? I know my solenoids work if I put power to them. But I just want to make sure they work together with the NOS Mini. Everything seems to be wired correctly but I wanted to test it before I put some nitrous through it.
Old 08-30-2018, 08:34 PM
FourG63 97GST
FourG63 97GST's Avatar
the controller will need to see RPM to trigger, you can do work arounds if you dont want to spray into motor, can test with the bottle closed, or test with the nozzle/plate line not connected, set the rpm window to a 1000 or something, so you can just rev and look at the disconnected line
Old 09-01-2018, 10:09 PM
Silver c6 z-51
Silver c6 z-51's Avatar
I have a nitrous outlet wet kit with a Nos mini progressive controller on my 05 Corvette. With the car on but not running I arm the system, go into your settings and drop your activation RPM to 0, once you save that setting then you can depressi your gas pedal, then you should hear your solenoids clicking. Of course you want the nitrous line clear.
Old 09-24-2018, 12:34 AM
emoFTW
emoFTW's Avatar
Thanks bud, that is exactly what I did after making this post!
To Test Nos mini with car off?
Quick Reply: Test Nos mini with car off?
